Advancing Ignition Timing?
Old Feb 18, 2004 | 01:38 PM
AnitRiceSuperStar's Avatar
Default Advancing Ignition Timing?
I went to advance my timing. I hooked up the jumper wires and the timing light sensor to the cylinder furthest away from the distributor(usdm driver side). I turned the distributor towards the firewall. The timing marks a lil to the right. Did I advance the timing or retard it? (It sounded like the rpm went up about 100rpm at idle)
Old Feb 18, 2004 | 02:01 PM
tilt's Avatar
Default Re: Advancing Ignition Timing? (AnitRiceSuperStar)
advanced. you forgot to warm up the engine and jumper the ecu service plug
Old Feb 18, 2004 | 02:10 PM
Default Re: Advancing Ignition Timing? (tilt)
koo..yeh it warmed up till the fan came on..i did the jumper on the driver side wheel well.. thanks man
Old Feb 18, 2004 | 02:18 PM
civickiller's Avatar
why do you need to do that jumper thing ? what exactly do you do ?
Old Feb 18, 2004 | 02:35 PM
-KangaRod-'s Avatar
it sends the computer into limp mode. If you don't jump it, the computer will keep correcting as you turn it. It is a little blue socket above the ecu on the passenger side. Jam a paper clip in both sides (connection), and it sends the computer impotent mode.
Old Feb 18, 2004 | 09:24 PM
Default Re: (-KangaRod-)
on 88-89 its in the engine compartment..driver side white and brown wire i think
Old Feb 18, 2004 | 09:42 PM
b16_madman's Avatar
Default Re: (AnitRiceSuperStar)
gaw i need to check mine b/c when we did it a long time ago i don't think we did the jumper wire. i though that was just for obd-1's
so i'm at 17 * advanced according to the timing light
stock 15* + or - 2 right?
beocop
Dec 15, 2016 09:05 AM
b20z2
Aug 8, 2005 11:57 AM
type Gendy
May 18, 2003 02:53 PM
g5r
Apr 7, 2003 08:51 PM
Etylorcen
May 26, 2002 07:30 PM
