pop off valves? anyone use one?
Old Feb 18, 2004 | 09:48 AM
twkdCD595's Avatar
Default pop off valves? anyone use one?
what the topic says... I see them used in the rx7's and others but I have yet to ever see one or hear of someone looking to get one for their f/i honda.
Old Feb 18, 2004 | 09:49 AM
Mr. Softee's Avatar
Default Re: pop off valves? anyone use one? (twkdCD595)
i heard some mention of them back in the day but have never seen one on anyone's car.
Old Feb 18, 2004 | 05:50 PM
twkdCD595's Avatar
Default Re: pop off valves? anyone use one? (94goldjungsr)
bump...
must very few and far between when heard of or use one.
Old Feb 18, 2004 | 06:36 PM
Flamenco-T's Avatar
what's a pop valve ?
Old Feb 18, 2004 | 06:40 PM
Bailhatch's Avatar
Default Re: pop off valves? anyone use one? (Flamenco-T)
opens at a certain pressure. not vac asssisted. For overboost protection
Dr Honda's Avatar
I used one in an old RayJay kit for a VW dunebuggy. It's old school. a wastegate works better.
The problem is that it will cut the boost... but it allows the turbo to over spool, and produce heat. A waste gate keeps the RPM's down to match boost pressure.
Old Feb 18, 2004 | 06:43 PM
twkdCD595's Avatar
Default Re: (Dr Honda)
I was not suggesting in place of a wastegate, but rather as an overboost safety measure.
Old Feb 18, 2004 | 07:06 PM
rtype11's Avatar
its actually was mandatory in the hey day of F1 racing so that the FIA could be sure that no team was overboosting the set max of I think 35psi, the pop off valve would blow and effectively keep the car from making more than 30psi afterwards, to fit one on street car would be a form of redundancy incase the wastegate did not function. kinda overkill unless you do not trust the second hand wastegate you bought off ebay.
PARADOX_sf
Apr 2, 2008 12:49 AM
nonvteclude
Jul 5, 2007 10:22 PM
dphonesavang
Aug 15, 2005 07:47 AM
ZoRG
May 28, 2004 11:08 PM
_Endless_
Jan 8, 2003 11:24 PM
