Bad CV?
Old Feb 18, 2004 | 06:21 AM
superpirate25's Avatar
Default Bad CV?
Old Feb 18, 2004 | 11:14 AM
GolfballSi's Avatar
Default Re: Bad CV? (superpirate25)
sorry for not answering your questions, but on the same note, how long can you drive on bad cv joints? mine makes noise on sharp turns + gas, but fine otherwise. money is tight right now, so i was wondering how long can i wait?
Old Feb 18, 2004 | 12:15 PM
greebler's Avatar
Default Re: Bad CV? (GolfballSi)
If it is a metal clicking noise its the CV, and yes it is bad to drive. If you mess it up too bad u need new axles. Go to a local shop and have them db check this, they will tell u what is wrong for free. Just act intrested in having them fix it.
Old Feb 18, 2004 | 12:27 PM
Perfectionist's Avatar
Classic symptoms of worn outer CV joints. Turning left or right can indicate which side the joint is failing on. Noise both ways = both sides going bad.
You can run on loose or failing joints. No one can say for how long though. Just hang on when they do let loose and flail around at 60mph.
Old Feb 18, 2004 | 02:34 PM
GolfballSi's Avatar
Default Re: Bad CV? (greebler)
it's not so much a metal clicking noise, but rather a humming noise. still cv?
Old Feb 18, 2004 | 02:50 PM
Duster's Avatar
could be bearings....in my car it starts to kinda whine / grind intermitantly when the bearings are shot...
picthis1
Dec 17, 2017 07:54 PM
tuan...
Aug 2, 2004 06:31 AM
tyflip2
12
Nov 22, 2003 07:42 AM
ghettols
14
Aug 15, 2003 12:52 PM
