Anyone Here using a T04b/T3 S3 trim?
Old Oct 10, 2001 | 07:41 PM
Rob03Pro5's Avatar
Default Anyone Here using a T04b/T3 S3 trim?
Hey fellas.. I was wondering if any of you with the T4/T3 hybrids are running a T04b S3 wheel. If so, how quick does it spool for you? what psi are you running and what are your hp/tq numbers if you've dyno'd. Thanks!
Old Oct 10, 2001 | 07:48 PM
JM Performance's Avatar
Default Re: Anyone Here using a T04b/T3 S3 trim? (Rob92SC)
I will be when my kit comes in.
Old Oct 10, 2001 | 09:15 PM
Rob03Pro5's Avatar
Default Re: Anyone Here using a T04b/T3 S3 trim? (00SilverLS)
great.. keep me posted on it! Anyone else?
Old Oct 10, 2001 | 10:06 PM
dbman96's Avatar
New User
I'm running the S3 wheel it seems good but I'm also running an 0.48 exhaust housing which chokes my top end something fierce.
Old Oct 11, 2001 | 02:57 AM
Default Re: Anyone Here using a T04b/T3 S3 trim? (dbman96)
but which engine do you have? not the b18b, right?
the only engines around here that the T04b/T3 S3 at .48A/R is good for really is the LS, because of the low redline. Anything else will def. be choked.
Old Oct 11, 2001 | 08:12 AM
dbman96's Avatar
New User
Yeah, exactly I'm on a B18C; the S3 wheel is fine up to the high redline; the 0.48 just blows monkeys.
Old Oct 13, 2001 | 09:01 AM
Rob03Pro5's Avatar
dbman,
Any hp or tq numbers? What psi are you running and when do you achieve full boost? Thanks.
Old Oct 15, 2001 | 08:52 PM
Rob03Pro5's Avatar
that's it? only 2 people on this forum with the T04b S3 wheel? How 'bout some beer.. would that get you fellas to reply??
550whpcivic
Jan 31, 2011 02:59 PM
songling
May 7, 2006 02:44 PM
PeakBoost
Jan 30, 2005 05:51 PM
B20bTurbo
Nov 22, 2002 03:39 PM
