torque spec ? for valve cover and studs.
Old Feb 17, 2004 | 03:36 PM
dpine's Avatar
Default torque spec ? for valve cover and studs.
I replaced my valve cover gasket the other day and over torqued 2 of the studs. They happened to be to 2 the ones that also hold down the cam caps( the 4 studs in the middle of the valve cover between spark plug wires). I got two new studs but I need to know the torque specs and the studs need tightened down to on the cam caps, and also so I don't bust anymore studs, what are the torque specs for the nuts that tighten down the valve cover?
thanks
Old Feb 18, 2004 | 03:44 PM
dpine's Avatar
Default Re: torque spec ? for valve cover and studs. (dpine)
please someone help. Ive been told 12lbs, 16lbs,20lbs. I just don't wan to screw anything up in the motor. Its the bolts/studs that go on the cam covers underneath the valve cover.
Old Nov 21, 2004 | 12:01 PM
_RevHardD15's Avatar
just tighten them hand tight, and turn the wrench 1/8th of a turn and you should be good to go, aluminum ***** up easy so dont tighten too much, and they dont need to be too tight
Old Nov 21, 2004 | 12:09 PM
Nikoli's Avatar
Default Re: torque spec ? for valve cover and studs. (_RevHardD15)
hand tight
Old Nov 21, 2004 | 12:43 PM
IO_303's Avatar
Default Re: torque spec ? for valve cover and studs. (Deckedlude)
chiltons says 12ft/lbs
Old Nov 21, 2004 | 01:00 PM
LudeyKrus's Avatar
Just tighten them hand-tight.
Old Nov 21, 2004 | 04:04 PM
notstock93's Avatar
Default Re: (LudeyKrus)
Yep, I thought it was about 7lbs, but hand tight should do it. No worries.
acmoc
Jul 3, 2008 05:39 PM
BrianCivicDX
Oct 3, 2006 02:57 PM
dpine
Feb 18, 2004 08:20 PM
Phoenix_ITR
Jun 17, 2002 07:10 PM
1fastGSR
Oct 1, 2001 04:20 PM
