Header install questions...
Old Feb 17, 2004 | 01:41 PM
variablevalve's Avatar
Default Header install questions...
Just some questions I have about installing headers.
1. On old carburated cars you needed to readjust the jets when u installed new headers - do you need to do anything like this?
2. Do you need a fitting clamp to hold the headers to the cat or are the screws enough.
3. How much are exhaust manifold gaskets from the dealership? ... (where i can i get them cheaper?)
Old Feb 17, 2004 | 01:58 PM
evilhatch2.0's Avatar
Default Re: Header install questions... (variablevalve)
what kind of cars are you installing them in????
on a fuel injected honda, all you have to do is remove the old ones ands install the new ones, you can even use the same gasket.
Old Feb 17, 2004 | 03:09 PM
Default Re: Header install questions... (evilhatch2.0)
sorry, this is install on a 94 civic ex
I can use the same gaskets? even after 160k miles?
Old Feb 17, 2004 | 03:32 PM
prostreetonline's Avatar
You can get a new OEM Exhaust manifold gasket here:
http://www.prostreetonline.com...X9295
Old Feb 20, 2004 | 07:32 AM
Default Re: (prostreetonline)
same question: could I use my stock gaskets even after 160k or will i need new ones?
Old Feb 20, 2004 | 08:16 AM
haggar's Avatar
Default Re: (variablevalve)
In response to the other question..
you used to change jets because with the headesr, you have more efficient airflow, so you could use more fuel to keep the air/fuel ratio where you wanted it.
On the honda, in closed loop, it will adjust automatically. In Open loop (wide open thottle), it isn't going to adjust for it. You'll run a little leaner after adding headers, or an intake, cams, etc.
Thats why people either: a)get a new 'chip' for their ECU b) increase the fuel pressure a little to put more fuel in the engine c) use a S-AFC/V-AFC to add extra fuel d) Use something like Hondata/UberData/TurboEdit, etc to adjust the computer settings to add more fuel.
Those things are the equivalent of changing the jets(and a lot more, too).
If you aren't making a lot of changes, then using a S-AFC or something will be good for fine tuning, best done on a dyno. Rasing the fuel pressire a bit will also work.
killerpenguin21
10
Nov 13, 2006 04:03 PM
hwtfan
May 5, 2006 08:10 AM
rob1208lv
11
Sep 19, 2002 09:33 AM
Wet Nudl
Apr 24, 2002 06:02 PM
SamC
Nov 16, 2001 03:16 PM
