HID in CRX!?
Old Feb 17, 2004 | 11:49 AM
JToolz's Avatar
Default HID in CRX!?
My headlights are extremely weak and I wanted to install this kit in my CRX.
Old Feb 17, 2004 | 11:50 AM
JToolz's Avatar
Default Re: HID in CRX!? (JToolz)
The kit includes: 2 philips d2s bulbs, 2 hella ignitors, 2 hella ballasts, and 2 wire harnesses. Is this all I would need? Thanks
Old Feb 17, 2004 | 12:02 PM
kid-honda's Avatar
I just use 9005 bulbs for my regular beams and the work great for visibility.
As for hids I dont know a damn thing.
Old Feb 17, 2004 | 12:07 PM
krazie1's Avatar
BANNED
yeah that should be all u need for it
i got some on my ef sedan
so as long as every plugs into everything including ur stock light bulb harness it is plug in a play
but if not u need a harness from the chasis harness to the ballast
Old Feb 17, 2004 | 01:37 PM
Benskins's Avatar
those bulbs might melt your stock head light housings, be careful
Old Feb 17, 2004 | 02:17 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: (Benskins)
HID bulbs are only 35 watts, i din't think you have to worry about melting.
I'm runing on oem S200 HID system in my CRX with APC projo's.
Deetz
Old Feb 17, 2004 | 02:19 PM
bryant's Avatar
Default Re: (Deetz)
Look up in the FAQ link at the top of the CRX/Civic Forum and near the end is a link to my old OEM HID how to post into crx headlights. It should help you out a ton.
Old Feb 17, 2004 | 02:49 PM
Doctor CorteZ's Avatar
Default Re: (kid-honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kid-honda &raquo;</TD></TR><TR><TD CLASS="quote">I just use 9005 bulbs for my regular beams</TD></TR></TABLE>
Old Feb 17, 2004 | 02:55 PM
ghettocrxsi's Avatar
Default Re: (Doctor CorteZ)
HId will not melt your houseing. They run cooler than a stock 9006 bulb. Make sure those d2s bulbs have a 9006 base or you are going to have to do some custom work to get them to work.
Check in the FAQ at the top like Bryant said.
Old Feb 17, 2004 | 04:16 PM
StorminMatt's Avatar
The whole point of HID is higher efficiency. HID lights convert a MUCH higher percentage of input power into actual light. So (1) less heat is produced because less is wasted, and 92) less is produced because less power is required to produce the same amount of light.
Old Feb 17, 2004 | 05:11 PM
CRXRageD's Avatar
I still need to install my Catz 9006 kit in my crx.
kixcrx
Lighting
Nov 6, 2007 11:38 AM
C_Rock77
Lighting
Sep 19, 2007 05:32 AM
matt21civ
Honda Civic (2001 - 2005)
Jul 24, 2006 05:29 AM
dorifto_83
Jan 27, 2006 05:35 AM
EX-JAY
Mar 19, 2005 07:50 PM
