b18c1 timing desperate help!
is there anything i need to do with the distributor before putting it on? also, when i put the camshafts in, the are both kinda crooked (the "up" arrows are a facing towards each other a little)....how do i adjust that?
hope this makes sense.
put your motor at TDC... by lying up the white line on your crank pulley to the little pointer. With that, your cam gears both should be pointing upwards exactly. If they are not, your cam gears are off a tooth or more. Do not start your car unless you are 100% sure that the cam gears are lined up correctly.
About the distributor, there is only one way a distribuotr can be put on. You just have to adjust it for timing issues though.
lsvtec101
Mar 21, 2003 03:31 PM
to Smooch Pickle
