ZC injector question
Old Feb 17, 2004 | 06:45 AM
stealthSI's Avatar
Default ZC injector question
I have rebuilt a new ZC motor & am putting it in a 91 Civic SI HB.
any idea what electronics make the fuel injectors work ?
and how I can test ?
I replaced the distributor- brand new- good spark now.
Motor will run with ether sprayed into air cleaner, but not getting any fuel thru injectors.
(ether going in thru intake valves keeps it running.)
Plugs are dry...
and I have plenty of fuel volume & pressure in fuel rail. PLENTY.
And I have electric signal at injector. Solid- not pulsing. Using test light.
I tried putting the old SI injectors in (which worked on car before)- no difference.
also tried 2 ECU's- original (PM6 from SI ) & a used PM7 that I bought- supposed to work
better with the ZC motor.
stumped again- any ideas ?? Many thanks !
Old Feb 17, 2004 | 07:28 AM
SloCivicHMM's Avatar
Default Re: ZC injector question (stealthSI)
hmm got the resistor box??
Old Feb 17, 2004 | 07:30 AM
stealthSI's Avatar
Default Re: ZC injector question (SloCivicHMM)
got it.
the old SI one worked before.
Was going to try another from a friend, but the plugs were different...
Old Feb 17, 2004 | 08:17 AM
hmmm are you sure you got the right injectors...I'm stumped too
my guess is the resister box is bad.....or diff obd injectors....sorry I'm not much help...
Old Feb 17, 2004 | 01:06 PM
stealthSI's Avatar
Thanks for trying...
I think it is possibly the wiring harness modification I made.
My instructions were not very good....
Anyone possibly have better wiring info on changing the round Honda
plug (at distributor) to the rectangular Acura plug ?
or the other way- I ended up keeping the round SI connector since
I didn't have female rect. plug.
KB
ohgodbadname
May 26, 2012 02:38 PM
Mojave
Jan 29, 2012 06:19 PM
Sobe_Death
Mar 13, 2004 02:02 PM
Morbspeed
Jan 13, 2004 05:51 PM
gregv
Dec 29, 2003 05:50 AM
