Where to get wastegate flange 35mm to merge with downpipe?
as stated!?
Also why is there a fitting (vacuum I assume on my compressor housing, right before it leads to the charge pipe?
what flange are you needing are you talking abotu the dump flange if so i have them here just let me know the nipple on the compressor housing of the turbo should run to your wg source
I thought the wastegate source ran from the IM to read vacuum, or does the wastegate need both compressor pressure and IM mani pressure?
Yeah the flange is for the dumptube to be rerouted into the downpipe.
What is the price on that?
you can run the wg source from the turbo or you can run it from the intake manifold just one source is needed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX »</TD></TR><TR><TD CLASS="quote">The WG should be fed from a source before the throttle plate, i.e. - not the intake manifold.</TD></TR></TABLE>
Your are partially correct,
you can feed the WG any source that can read postivie pressure no matter where it is located.
SI_frankenstein
Jul 16, 2011 03:45 PM
SI_frankenstein
Jul 8, 2011 12:05 PM
accordfreak
Aug 29, 2003 03:39 AM
Just going off what my TiAL instructions said.
