Will a D16Y8 tranny direct fit an EG?
Old Feb 16, 2004 | 09:23 AM
Suzukablue's Avatar
Default Will a D16Y8 tranny direct fit an EG?
Just like the topic says. I know the D16Z6 tranny will do but not sure bout the Y8. I would appreciate any input from you guys. Thanks.
Old Feb 16, 2004 | 10:01 AM
allmotaeg6's Avatar
Default Re: Will a D16Y8 tranny direct fit an EG? (eg_ko_2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg_ko_2 &raquo;</TD></TR><TR><TD CLASS="quote">Just like the topic says. I know the D16Z6 tranny will do but not sure bout the Y8. I would appreciate any input from you guys. Thanks.</TD></TR></TABLE>
yes it will bolt up
Old Feb 16, 2004 | 10:05 AM
skip.two's Avatar
it will fit in an EG
Old Feb 16, 2004 | 10:07 AM
yellowturbo's Avatar
does the gearing is the same and which one is stronger ???
Old Feb 16, 2004 | 10:19 AM
skip.two's Avatar
Default Re: (yellowturbo)
the y8 tranny is only better than the z6 because the y8's have steel shift forks and z6's have aluminum shift forks.
Old Feb 16, 2004 | 12:18 PM
Suzukablue's Avatar
Thanks for the help guys. Anything I should know before picking up my Y8 tranny? Any parts/modifications needed or just buy it and slap it in? Any pointers you can give me when buying the tranny? On the transmission it says p20 B000. would this be the right one?
Old Feb 16, 2004 | 12:23 PM
BauleyCivic's Avatar
Risky Business
Default Re: (jL iLLuZiOnz 9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jL iLLuZiOnz 9 &raquo;</TD></TR><TR><TD CLASS="quote">the y8 tranny is only better than the z6 because the y8's have steel shift forks and z6's have aluminum shift forks.</TD></TR></TABLE>
Correct The Y8 and Z6 gearing is identical
tobe1424
11
Dec 6, 2005 09:43 PM
ME SO FST
34
Jan 28, 2005 10:49 AM
Shotman
10
Dec 30, 2004 04:17 PM
yellowturbo
12
Nov 9, 2004 12:56 PM
95cxhatch
Jan 6, 2004 08:04 AM
