V-AFC II, looking for someones settings
Old Feb 15, 2004 | 09:20 PM
Syner-G-Racing LLC's Avatar
Default V-AFC II, looking for someones settings
whats up I have a 96 B18C ITR and Ive got the VAFC II that I installed, Im looking for someone who has already dyno'ed theirs to compare our settings. Im curious how different they are and I would like to have some settings to play with.
Old Feb 15, 2004 | 09:25 PM
jdmspoonitr's Avatar
Default Re: V-AFC II, looking for someones settings (Syner-G-Racing)
The only thing that seems relatively consistent is that with a stock motor the car seems to benefit from a 4600 crossover. All of the other information will not help you as people have tuned on a dyno for their specific modifications. Even if you have the same mods all motors react differently. I wouldn't drop the vtec crossover unless you get it on a dyno though. You need to see what the a/f ratio is. There is no universal tuning diagram.
Old Feb 15, 2004 | 09:28 PM
yeah I know theres no universal tunning but Im curious to see other peoples settings I have quit a bit Ive done to the engine. Im looking to see if there similar. a N/A setup though
Old Feb 15, 2004 | 09:34 PM
B2FiNiTY's Avatar
-2 at 8000 rpm and -1 at 7800 rpm.
Old Feb 15, 2004 | 09:37 PM
Default Re: V-AFC II, looking for someones settings (B2FiNiTY)
VTEC umatched (fuel correction to compensate for difference of ecu and controller)
Narr Throttle (air correction in relation to throttle position)
wide throttle (" ")
VTEC cont (vtec engagement point)
Throttle Position ( at what percentage the vafc maps take over the ecus maps)
those are the parameters Im a interested in seeing.
Modified by Syner-G-Racing at 1:49 AM 2/16/2004
Old Feb 15, 2004 | 09:40 PM
B2FiNiTY's Avatar
What are you talking about?
Old Feb 15, 2004 | 11:14 PM
IGGY's Avatar
I there is no specific for every car, but you switch the VTEC crossover according to a dyno. Then you add fuel at the cross over and take away in the higher RPMs.
Old Feb 15, 2004 | 11:55 PM
Pompiuses's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syner-G-Racing &raquo;</TD></TR><TR><TD CLASS="quote">whats up I have a 96 B18C ITR and Ive got the VAFC II that I installed, Im looking for someone who has already dyno'ed theirs to compare our settings. Im curious how different they are and I would like to have some settings to play with. </TD></TR></TABLE>
Check it out:
https://honda-tech.com/zerothread?id=709136
https://honda-tech.com/zerothread?id=531773
Old Feb 16, 2004 | 07:52 AM
kshymkiw83's Avatar
96 R? where did you aquire it from?
gsrx
Nov 24, 2004 02:12 PM
sirminder
Dec 19, 2003 08:29 AM
satan_srv
Sep 13, 2003 11:32 AM
DB8
Jun 14, 2002 12:40 AM
