2nd to 3rd gear grind!!!
Old Feb 15, 2004 | 08:13 PM
danny98r's Avatar
Default 2nd to 3rd gear grind!!!
have been experiencing 2nd to 3rd grinding with my 98 type r. dealer is fixing it now. how many people have had this problem? gm synchromesh did not cure the problem. only grinds at 7500rpm. annoys the hell at of me.
Old Feb 15, 2004 | 08:52 PM
TypeR15's Avatar
Default Re: 2nd to 3rd gear grind!!! (danny98r)
ya i had 2nd to thiird all fixed though
Old Feb 15, 2004 | 08:58 PM
itr 00 0108's Avatar
No fluid is going to *cure* the problem...they only put a bandaid on it for a while....once you have a grind, you aren't going to get rid of it...
Old Feb 15, 2004 | 09:44 PM
Syner-G-Racing LLC's Avatar
Default Re: 2nd to 3rd gear grind!!! (itr 00 0108)
Ive had this problem several times its your syncro's when they start going out it doesnt allow for proper spin up of your gears causeing a grind and severe situations engagement of the gear especialy at high rpms. Fluids like red line or royal purple lucas stabilizer only help to cushion rough shifts (slight grind). Install new syncros and you'll thank youself later.
Old Feb 15, 2004 | 10:35 PM
R you serious's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danny98r &raquo;</TD></TR><TR><TD CLASS="quote"> how many people have had this problem? gm synchromesh did not cure the problem. only grinds at 7500rpm. annoys the hell at of me.</TD></TR></TABLE>
welcome to the wonderful world of honda
Old Feb 15, 2004 | 11:07 PM
IGGY's Avatar
Default Re: 2nd to 3rd gear grind!!! (R you serious)
I've had that happen before. It was a bad syncro. I got it replace under warranty.
Old Feb 16, 2004 | 05:36 AM
JiggyKooAndy's Avatar
Default Re: 2nd to 3rd gear grind!!! (IGGY)
how many miles on your car? When do the synchros usually start to go out? Mine sort of grind...only at times though, so i'm wondering if that's the start of the problem...?
Old Feb 16, 2004 | 05:57 AM
rizen's Avatar
I put 60k miles on my tranny before this infamous problem started to occur...
Put in the synchromesh and it 'aided' the shifts a little, but the grind is still there and the notchyness is only getting worse overtime.
Eventually, i'll pull the aftermarket clutch out and have Acura warranty the tranny as they should.
I don't powershift my car (it's not turbo) and nor will I.
Old Feb 17, 2004 | 01:01 PM
Mugen Type R's Avatar
got that in my 98 R too, need a synchro my friend.. im lookin into cheap labor..
Old Feb 17, 2004 | 01:07 PM
Grip's Avatar
Default Re: (Type R 98-870)
how much does it cost to have synchros replaced?..my motor grinds 2nd to 3rd also
Old Feb 17, 2004 | 03:27 PM
mstyper's Avatar
syncro's
Old Feb 18, 2004 | 04:09 PM
amy's Avatar
amy
Default Re: (Grip Driver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grip Driver &raquo;</TD></TR><TR><TD CLASS="quote">how much does it cost to have synchros replaced?..my motor grinds 2nd to 3rd also </TD></TR></TABLE>
im curious about this also....... i hate my third gear grinds.. ive had it in both trannys my car has had...
Old Feb 18, 2004 | 04:29 PM
ScorpioX's Avatar
Default Re: (amy del sol)
i had the same problem....
replace ur 2-3rd synchro and dont powershift from 2nd to 3rd anymore
they are fragile on honda trannys...
808k20z3
Honda Civic (2006 - 2015)
Jan 21, 2007 10:55 AM
meblahu
Dec 1, 2006 05:39 PM
peel17
Dec 6, 2005 03:01 PM
soundcheck187
Jul 15, 2005 04:49 PM
