Car dies with hondata
Old Feb 14, 2004 | 11:33 AM
Kidd_Stylez's Avatar
Default Car dies with hondata
I have a 94 turbo, vtec prelude, only running 6lbs of boost and using a hondata S200B with all options for management. I finished the turbo install yesterday and went to take it for a ride. Whenever the car starts to boost or right about 3K rpm, the car just hits a wall. It does not cut off, but the fuel cuts. Its not like i am bouncing off of the rev limiter, the car just rocks as if you are popping off the gas petal from wide open throttle even though i am only 15% into the throttle. I searched and no one with a hondata had a problem like this. Can anyone help?? The reason i blame the management is because i have trouble shooted everything else. Thanks for any info.
Old Feb 14, 2004 | 11:45 AM
Blackack26's Avatar
Default Re: Car dies with hondata (Kidd_Stylez)
quoted from hondata's website...
The engine will only rev to 3200 rpm:
In this situation the error codes cannot be retrieved from the ECU (the check light will remain on solidly). The ECU is in ‘limp home mode’, which means that there is a problem accessing the ROM so the ECU is running off a backup processor. The ECU will use fixed ignition and fuel values. Possible causes for this problem:
• ROM inserted the wrong way around.
• Incorrect ROM for the ECU (see page 6).
• Jumper J1 not installed or incorrect value.
• Bad solder connection to the socket or latch IC (especially with surface mount latch ICs).
BTW you shouldn't be boosting on your basemap
Old Feb 14, 2004 | 11:57 AM
Mase's Avatar
Default Re: Car dies with hondata (Blackack26)
i hope you arent running a basemap trying to boost without a wideband to monitor afr....
Old Feb 14, 2004 | 12:01 PM
"Blackack26" where is that link?? I was not trying to boost on my base map, i was just "limping" home. I am going to tune it tonight. Thanks
Old Feb 14, 2004 | 12:02 PM
Mase's Avatar
check the hondata box, is it blinking or is it solid light?
Old Feb 14, 2004 | 12:05 PM
Default Re: Car dies with hondata (Mase)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase &raquo;</TD></TR><TR><TD CLASS="quote">i hope you arent running a basemap trying to boost without a wideband to monitor afr....</TD></TR></TABLE>
I wanted to find out what this problem was first, just to make sure everything was hooked up right. Later today i will be using a laptop as well as a wideband to tune.
I know that car has / needs to be tuned. Is that all it will take to make this problem go away?
Old Feb 14, 2004 | 12:06 PM
solid light, i am also search hondata's site
Old Feb 14, 2004 | 12:09 PM
Mase's Avatar
if i were you, if you arent getting a check engine light or a blinking hondata light, id hook up your wideband, and see what afr its jumping to. it could just be running really lean at that spot.
Old Feb 14, 2004 | 12:16 PM
i am about to go do that now, i will post later tonight with results, thanks for all your help
-C-
ThinHoanG
Mar 17, 2005 04:04 AM
B18C1CYA
Apr 17, 2004 09:00 PM
DR. ON POINT
Sep 6, 2002 09:47 AM
servion
Aug 11, 2002 12:02 PM
