couple questions concerning my b18c swap into my da9
question #1 where does the bottom of the fpr go i cant seem to find where it used to go to. #2 i am running without a PS pump is it possible to just run the two extra lines into the old resavour until i can buy the parts i need to take all that stuff out.
There's a black hose going into the firewall, the other end needs to go to the bottom of the FPR, it's the fuel return. If you want to keep your P/S just use the B18A crank pulley, DA P/S pump and belt and get a B16A/B17A upper P/S bracket and you're set.
phantom_sol
13
Mar 5, 2004 03:34 AM
