APEXi VAFC
Old Oct 9, 2001 | 02:42 PM
unltdacc12's Avatar
Default APEXi VAFC
Does anybody here have on installed?.. i wanted to get some info on settings and what parts your running with the VAFC. right now im have I/H/E pulleys, fuel rail, and pressure regulator.. i wanted to get a basic idea of where to set mine.. any suggestions would be appreciated.. thanks
Old Oct 9, 2001 | 04:26 PM
SOHCArchangel's Avatar
Default Re: APEXi VAFC (unltdacc12)
i do, set it low, but not too low, just play around with it.....
Old Oct 9, 2001 | 07:13 PM
John's Avatar
New User
do you have a cam gear? that'll definitely make a difference... as for the VTEC threshold, I have mine pretty darn low... at 3500rpm... but it gave a nice addition to my power curve between 3500 and 5200 rpm... as for the A/F ratio settings, that should probably be done on a dyno... but by leaning out from 5.5K and up will help a bit...
Old Oct 9, 2001 | 08:44 PM
John's Avatar
New User
Default Re: APEXi VAFC (DunReit)
oh, i forgot to say that every motor is different... so the best results will be produced from your V-AFC on the dyno...
Old Oct 10, 2001 | 05:09 AM
Big James's Avatar
New User
DYNO TUNE IT! Trying to do the settings yourself is just asking for trouble. You could actually loose power.
Old Oct 10, 2001 | 05:28 AM
John's Avatar
New User
Default Re: APEXi VAFC (Big James)
Or if you want to hold off on dynoing it, you can get an air fuel meter and watch the air fuel ratio through the power band... Where it gets too rich, lean it out with the V-AFC at those rpms, where the mixture gets too lean, richen it out at those rpms. Keep in mind two things... the air fuel mixture produces optimum cylinder pressure between 12.5 and 13.5 (or is it 13.0 and 14.0?). Secondly, richen out the mixture a tad just before VTEC kicks in (whatever you set it at)... it helps to have the mixture a bit richer just before the VTEC kicks in since there is such a surge in torque at that rpm (when the VTEC is not at the OEM setting).
Also, I recommend that you get a cam gear and retard the timing a bit. On our cars (SOHC VTECs), advancing the timing yields more low end power, and retarding the timing produces more high end power...
Old Oct 10, 2001 | 06:51 AM
4doorH22's Avatar
http://www.members.aol.com/ryoucold/...pexi/apexi.htm
Old Oct 10, 2001 | 08:49 AM
unltdacc12's Avatar
Default Re: APEXi VAFC (4doorH22)
Thanks for the info.. ill try to mess with it
gsrx
Nov 24, 2004 02:12 PM
giser
Aug 25, 2004 07:26 PM
OneslowEP3
Jan 6, 2004 08:55 PM
supernova1400
Dec 14, 2003 10:17 PM
VTECivic4
Mar 20, 2003 10:55 PM
