engine swap question
Old Feb 12, 2004 | 06:13 PM
Jagolas's Avatar
Default engine swap question
i have a 93 ex with d16z6. piston rings are bad. local engine guys quote 1) 1000 to rebuild and 2) 400 labor with parts (but said i need to redo everything including crank, head and bottom end with oil pump). what swap can i do with like a jdm engine that bolts right on. i heard some of the zc d15b motors will work. i have like a 1k to work with plus a dismantled b18b1 engine minus dizzy in my garage. what would be best for now. the b18b needs to have a cylinder sleeved and then built. thanks for the help
Old Feb 12, 2004 | 06:24 PM
Jagolas's Avatar
Default Re: engine swap question (jagolas)
anyone got suggestions?
Old Feb 12, 2004 | 06:26 PM
iHave2Cams's Avatar
you can find a d16y8 motor very cheap, for like 400 bucks , the last time i check/bought one. Thats just the long block tho
Old Feb 12, 2004 | 06:29 PM
Jagolas's Avatar
Default Re: engine swap question (iHave2Cams)
but won't i have to convert to obd2?
tamadrummer1120
Mar 11, 2012 08:27 AM
flash69
Mar 12, 2009 08:08 PM
1999CivicSi
Nov 20, 2005 02:21 PM
civicproblems
Jan 14, 2005 01:39 PM
leonard
Dec 19, 2001 02:11 PM
