left turn signal acting weird
Old Feb 12, 2004 | 03:12 PM
itr 00 0108's Avatar
Default left turn signal acting weird
Ok, I have a 91 accord with 245k on it....everything runs perfect. All the electronics work and everything....
Recently, my left turn signal seems to pick and choose when it wants to work. Sometimes it will come on...other times it won't....most of the time it works....
Tonight on my way home was the worst instance yet....it wouldn't come on for five minutes or so....then I had to make a left turn and voila, as if the car had eyes, it worked!
I don't like not having a turn signal some of the time though...i'd hate to get a ticket for failure to signal...
I'm guessing it is a bad connection somewhere....all bulbs are in working order...
Only mod is an intake.
Thanks for any input guys.
Old Feb 12, 2004 | 03:15 PM
The_Todd's Avatar
Farts in the shower
Default Re: left turn signal acting weird (itr 00 0108)
I would say check your socket connectors (the metal spring like things in the bottom of the socket may have gotten beaten down), check your wires going to the socket too. Just a starting point.
Old Feb 12, 2004 | 03:22 PM
Default Re: left turn signal acting weird (VRDrvr)
Good idea....I think I can explain this differently...just to make sure everyone understands....
The bulbs physically work fine when they come on...but when they don't, I dont' have the green arrow or anything. When they weren't working, I put my 4 way flashers on and only the right arrow and the right side blinkers came on...
So it's not just the blinkers themselves, it's also the little green arrow that you get when you put your signal on. Hope that helps a bit more...
Old Feb 12, 2004 | 03:23 PM
The_Todd's Avatar
Farts in the shower
I would lean towards a relay or bad ground then.
Old Feb 12, 2004 | 03:33 PM
LookingForVTEC's Avatar
I have a 91 accord and about two years ago I had the same problem and it ended up being my combination switch. But that would be the last thing I check because the combination switch is a little costly.
Old Feb 12, 2004 | 03:34 PM
Yikes! Where's that at and how much are we talking?
Old Feb 12, 2004 | 03:36 PM
I'm gonna check the whole wiring route...I've never heard of a combination switch though...
Old Feb 13, 2004 | 05:23 AM
JimBlake's Avatar
Default Re: (itr 00 0108)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr 00 0108 &raquo;</TD></TR><TR><TD CLASS="quote">I'm gonna check the whole wiring route...I've never heard of a combination switch though...</TD></TR></TABLE>That's your turnsignal/headlight/highbeam switch all combined together.
Old Feb 13, 2004 | 05:29 AM
The_Todd's Avatar
Farts in the shower
Default Re: (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">That's your turnsignal/headlight/highbeam switch all combined together.</TD></TR></TABLE>
hondaautomotiveparts.com lists the switch at 92 bucks...I would investigate all your other possibilities first
Old Feb 13, 2004 | 07:07 AM
I'm guessing it's number 14 on there? I'll have to do some investigating....
Old Feb 13, 2004 | 07:16 AM
The_Todd's Avatar
Farts in the shower
Yes number 14....but again check out your wires and your bulb socket, they are common problems (at least with mine) it may solve it, if it doesn't then I would investigate in your switch, hope this helps.
Old Feb 13, 2004 | 08:17 AM
JimBlake's Avatar
Default Re: (VRDrvr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VRDrvr &raquo;</TD></TR><TR><TD CLASS="quote">... but again check out your wires and your bulb socket...</TD></TR></TABLE>Yes. I always like to rule out all the cheap easy stuff first before I start buying expensive parts.
Old Feb 13, 2004 | 10:06 AM
RotaryBzzzz's Avatar
I've often thought combination switches could be fixed by just giving the whole thing a good cleaning and cleaning up exposed contacts (using sandpaper or an eraser)
Jim...any input on that?
Bad connectivity many times can be blamed on "grime" as I learned from emission repairs.
Old Feb 13, 2004 | 10:16 AM
The_Todd's Avatar
Farts in the shower
Default Re: (RotaryBzzzz)
When my switch went out the actual contacts for when you use the turn signal broke (since its a combination of plastic and metal), when I looked at it just the plastic pieces broke the metal connectors looks fairly clean.
Old Feb 13, 2004 | 11:12 AM
JimBlake's Avatar
Never had a turnsignal switch go bad, really. Closest thing was the little mechanism that cancels the turnsignals when you turn the steering wheel back to center. That had nothing to do with the contacts...
Sometimes(?) you can't even take the case apart without breaking something. But I've cleaned up other switches. Burnish the contacts with something like a pencil eraser. Sandpaper can cut thru the plating, then it'll corrode real quickly. Grease helps for corrosion, too, but old grease gets hard & opens the contacts. Usually all they need is clean out the grease & put new grease in.
Reminds me of the saying... 'you know you're an engineer if you've ever spent 3 hours trying to fix a $10 radio'
Old Feb 13, 2004 | 05:35 PM
Well the car has 245k so I guess something is bound to go wrong every now and again...you all have been of immense help. I really appreciate all the suggestions.
HondaAccord333
Feb 19, 2018 08:04 AM
lharper
Mar 22, 2017 10:40 AM
O RLY
Dec 13, 2006 06:54 AM
rkrone
14
Aug 26, 2006 06:38 AM
HRC
Aug 30, 2001 10:35 AM
