Double Cat?
Old Feb 12, 2004 | 02:36 PM
iGoneRacing_GSR's Avatar
Default Double Cat?
Has anyone ever tried running double catalatic converters? Do you think it'll pass the tail pipe test? I figure, if one is able to do it... then adding another will only make the exhaust cleaner... I can't think of anything wrong with having 2 cats under there...
Any thoughts?
Old Feb 12, 2004 | 02:42 PM
UNDER PRESSURE's Avatar
Default Re: Double Cat? (crx_b16a2)
It better pass a smog check with two cats.
Old Feb 12, 2004 | 02:44 PM
payneth's Avatar
Default Re: Double Cat? (UNDER PRESSURE)
sounds like a good idea to pass. i couldnt think of anything wrong with it.
Old Feb 12, 2004 | 02:59 PM
CRX Si's Avatar
Default Re: Double Cat? (OneSlowEF)
what a cat does is use heat to combine 2 molicules and make something different, So when It comes out of the first cat it is already gone through the process, Put it through another cat and nothing will happen. If it was that easy dont you think that every car out there would come stock with 2 cats... Dont waste your time...
Old Feb 12, 2004 | 03:00 PM
xci_ed6's Avatar
make sure it gets warm so the second one will light off, or you might clog the second one up faster from not running it at operating temp.
IDK though, im more for elimitating emmisions equipment :D
-Dustin
[edit in reply to above post]
Chemical reactions take time, and there is limited time in the first cat, so the second may provide more. And some cars do come with 2 or more cats in series.
[/edit]
Old Feb 12, 2004 | 03:07 PM
CRX Si's Avatar
Default Re: Double Cat? (krustindumm)
you wont be giving it more time though because by time it gets to the second cat it wont be combining the same molicules... And some cars still come with DPFI, doesnt mean its better or even makes sence
Old Feb 12, 2004 | 03:30 PM
Lo-Buck EF's Avatar
Default Re: Double Cat? (CRX Si)
i think what hes thinking about is cars that run real rich with big cams. those cars may not pass with one, but if u run 2 cats close to the exhaust manifold/header, then it may work. this is the same idea that the wrx operates under. it has 3 cats. 01-02 audi s4 had 4 cats.
-spenc
Old Feb 12, 2004 | 03:31 PM
[QUOTE=krustindumm]make sure it gets warm so the second one will light off, or you might clog the second one up faster from not running it at operating temp.
What could happen if the second cat clogs up? My engine won't choke would it? I figure, even if it doesn't heat up that much, exhaust would still flow through it... and it won't do any harm.
Thanks for the replies guys....
Old Feb 12, 2004 | 03:38 PM
4drEF's Avatar
Keyboard Humorist
It takes time for it to clog, but it's the honeycomb struture inside breaking down that clogs it. If it gets VERY clogged then it will start making lots of backpressure and will cause the engine to run terrible since the exhaust will be so overly restricted. I had one clog up and the absolute fastest the car would go was 35 mph with the pedal mashed to the floor.
EDIT: running rich and running lean both kill cats. Running lean is actually worse.
Old Feb 12, 2004 | 04:16 PM
spettinger's Avatar
Default Re: Double Cat? (4drEF)
my B16 was failing miserably with high flow cats. (duh.) i threw in 2 cats from an 03 mustang's H-pipe at my shop, quick passed in 15 seconds.
Old Feb 12, 2004 | 05:06 PM
90civichbsi's Avatar
Default Re: Double Cat? (91hatchattack)
nothing wrong w/ runnin 2 cats... Rx7's have a precat and main cat becaust they put out so much emmions.
as for the comment about running 2 cats not doing any good, cats dont work 100% all the time.. if the first one misses some of it the secod will hopefully get the rest.
Old Feb 12, 2004 | 07:29 PM
blah13's Avatar
Default Re: Double Cat? (90civichbsi)
Hell, some lincoln mark viii have 5, 2 per header then they both run into 1 more....more cats = lower emissions, perfect for passing the sniffer. I dont know how they'll react to a visual but I'm sure they cant complain.
Old Feb 12, 2004 | 07:39 PM
B2FiNiTY's Avatar
Sounds like a great way to pass
Extreez
Jun 29, 2007 06:11 PM
boosted94teggy
Oct 21, 2005 10:47 PM
EM1VtecSi
Feb 14, 2005 01:21 PM
Deep_Fried
Dec 14, 2003 11:48 PM
Canuk_SiR
Oct 30, 2003 08:50 AM
