DSM crushed BOV?
Old Feb 12, 2004 | 02:20 PM
Honda Sport's Avatar
Default DSM crushed BOV?
I've always wondered what that meant. anybody? what does it mean when it's crushed??
Old Feb 12, 2004 | 03:20 PM
so nobody knows??
Old Feb 12, 2004 | 03:21 PM
88ZCRX's Avatar
Default Re: (Honda Sport)
Basically what you do is, smash the top of the bov down a little bit to give the bov more spring tension to be able to resist popping off prematurely under higher boost levels.
Old Feb 12, 2004 | 04:04 PM
oh i c. thanks! info is power! hahahaha...
Old Feb 12, 2004 | 04:06 PM
FourG63 97GST's Avatar
I crushed mine today
I put a penny centered to the top of it, I put it under the press till I was satisfied, I'll say about 4mm
Old Feb 13, 2004 | 10:17 AM
you probably dont need to crush it, it tends to leak around 17psi, thats kinda inaccurate though, it really depends on what turbo your have. crushing will make it hold about 23-24psi. you prolly dont boost that much, best advice I can give here it make an intake leak tester and check if it leaks or not
mrjdmcivic
Jun 16, 2004 11:36 PM
d16tuner
Apr 23, 2004 01:26 PM
sledgehammer
Oct 12, 2003 10:06 PM
BlackB18CTeg
Oct 4, 2003 11:16 AM
