Cali legal swap owners: BAR sticker is for 1995 Honda 1.8L (B18C1) and I need to replace the head
Old Feb 12, 2004 | 07:48 AM
1's Avatar
Default Cali legal swap owners: BAR sticker is for 1995 Honda 1.8L (B18C1) and I need to replace the head
I am thinking of getting P73 head. I need to know how detailed the BAR people are. I believe the BAR info is taken from the block (serial # and VIN) and not the head. Anyone know for sure? I need to replace my head and using an ITR head is my preference.
Old Feb 12, 2004 | 10:20 AM
(JON)'s Avatar
Default Re: Cali legal swap owners: BAR sticker is for 1995 Honda 1.8L (B18C1) and I need to replace the he
bump for luck!
Old Feb 12, 2004 | 12:40 PM
temp's Avatar
it wont pass at the BAR
Old Feb 12, 2004 | 01:54 PM
Fobtions's Avatar
it should pass at the pipe , but visual i dont know for sure.
Old Feb 12, 2004 | 02:18 PM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions &raquo;</TD></TR><TR><TD CLASS="quote">it should pass at the pipe , but visual i dont know for sure.</TD></TR></TABLE>
it wont pass visual mainly due to the fact that the ITR IM is of a different design
Old Feb 12, 2004 | 05:37 PM
1's Avatar
temp, the car is already BAR-ed. My only issue is the smog guys. i guess it will really depend on if they know their stuff or not.
Old Feb 12, 2004 | 10:34 PM
APEX CRX's Avatar
if you already have a BAR sticker you should be ok with most places to have it smogged. I think most places won't give it a 2nd look once they see the BAR sticker
Old Feb 12, 2004 | 10:39 PM
bossman032's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 &raquo;</TD></TR><TR><TD CLASS="quote">I am thinking of getting P73 head. I need to know how detailed the BAR people are. I believe the BAR info is taken from the block (serial # and VIN) and not the head. Anyone know for sure? I need to replace my head and using an ITR head is my preference.</TD></TR></TABLE>
hmm it should work I don't see why it won't work.
they don't check the head they check the block if it says b18c then its b18c also if it pass it should get a sticker.
I been to bar like fucken 7-8 times I know they don't check the head
they see b18c somg as a GSR
Old Feb 12, 2004 | 11:43 PM
91civicEX's Avatar
unless you go to a honda engine rebuild shop and the smog inspector is having a really bad day i think you can sneak it by them. to tell you the truth i probably couldnt tell a C1 head from a C5. just worry about the fumes. and use ur black valve cover right?
Old Feb 13, 2004 | 06:34 AM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 &raquo;</TD></TR><TR><TD CLASS="quote">temp, the car is already BAR-ed. My only issue is the smog guys. i guess it will really depend on if they know their stuff or not.</TD></TR></TABLE>
ok then, you should not have a problem, but what ECU are you going to use?
Old Feb 13, 2004 | 06:44 AM
1's Avatar
The ECU is irrelevant as long as it passes the sniffer. They don't run tests on 0BD1, only on 0BD2.
Old Feb 13, 2004 | 06:48 AM
phan's Avatar
woah, since when do they not test obd-1?
Old Feb 13, 2004 | 06:51 AM
1's Avatar
phan, I mean they don't run a test on the ECU.
Old Feb 13, 2004 | 07:30 AM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 &raquo;</TD></TR><TR><TD CLASS="quote">The ECU is irrelevant as long as it passes the sniffer. They don't run tests on 0BD1, only on 0BD2.</TD></TR></TABLE>
actually it is relavent because if you run the GSR ecu w/ the ITR head you will get a CEL......so it is totally relavent
Old Feb 13, 2004 | 05:27 PM
fourthgenhatchB17's Avatar
A CEL for the GSR's secondary butterflies? A friend of mine had a SKUNK2 manifold on his GSR motor with stock ECU and he got no CEL's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp &raquo;</TD></TR><TR><TD CLASS="quote">
actually it is relavent because if you run the GSR ecu w/ the ITR head you will get a CEL......so it is totally relavent</TD></TR></TABLE>
Old Feb 14, 2004 | 08:13 PM
temp's Avatar
thats because the skunk2 mainfold for the GSR has the provision to have the butterfly solenoid doesnt it?
Old Feb 14, 2004 | 10:04 PM
Cruiser G's Avatar
I dont think the skunk2 mani has the provision for the butterflys. You wont get a CEL with them not hooked up though. Bump fo my dawwg!
hard_boiled_EG
Southern California
Apr 5, 2009 11:15 PM
dj theoretic
Mar 29, 2008 11:13 PM
92 BLUE EG6
Jun 15, 2006 02:57 AM
iLOVEmyEMone
51
Dec 21, 2005 06:27 AM
