Torque specs on Oil Drain bolt? any on oil filter?
You don't need to tq that stuff down. Hand tight for the oil filter and tight on the drain bolt. Don't stress.
Replace the oil drain bolt washer if needed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx »</TD></TR><TR><TD CLASS="quote">and the oil filter, is 7/8th of a turn.</TD></TR></TABLE>after the gasket touches.
the 7/8ths markings are around the Honda filter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">What do the markings look like? </TD></TR></TABLE>
little numbers around the middle of the filter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CWESTINDC2 »</TD></TR><TR><TD CLASS="quote">hey does anyone know the torque specs for the oil drain bolt? any specs for the oil filter?</TD></TR></TABLE>
from FAQ - Torque Specs Section
https://honda-tech.com/zerothread?id=317728 - Oil Filter - 7/8th Turn Clockwise or 16 Lbs/Ft
https://honda-tech.com/zerothre...91836 - Oil Pan Drain Bolt - 33 Lbs/Ft
EJ8_Enthusiast
14
May 17, 2012 08:02 AM
itrsport.com
Oct 12, 2003 05:19 PM
