5 point harness
Old Feb 11, 2004 | 10:18 PM
zzzhondazzz's Avatar
Default 5 point harness
Does anyone know if theres a law about a 5 point harness in illinois??
Old Feb 12, 2004 | 01:18 AM
Riceburner247's Avatar
Default Re: 5 point harness (zzzhondazzz)
what kind of law?
Old Feb 12, 2004 | 03:03 AM
urbanlegend21's Avatar
New User
Default Re: 5 point harness (riceburner247)
5 point harnesses are not DOT approved so therefore they are illegal
Old Feb 12, 2004 | 10:23 AM
.bagged's Avatar
Default Re: 5 point harness (urbanlegend21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urbanlegend21 &raquo;</TD></TR><TR><TD CLASS="quote">5 point harnesses are not DOT approved so therefore they are illegal</TD></TR></TABLE>
Which is stupid but true
Old Feb 12, 2004 | 02:02 PM
New User
Default Re: 5 point harness (bagged93accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bagged93accord &raquo;</TD></TR><TR><TD CLASS="quote">
Which is stupid but true </TD></TR></TABLE>
no it is not, harnesses are deadly unless in a car with a roll cage or roll bar, which would have to be regulated by the DOT as well
if you were to rollover in a car with a harness and no roll over protection your head would be like a golf ball on a tee because your body would not move from the neck down
a regular seatbelt lets you move side to side and fall out of the way
in VA you can have a harness setup approved by an inspector on an individual basis
Old Feb 12, 2004 | 03:09 PM
.bagged's Avatar
in VA you can have a harness setup approved by an inspector on an individual basis</TD></TR></TABLE>
So how would a roll cage prevent your head from acting like a golf ball? You would still get tossed around roll cage or not..dont you think
Old Feb 13, 2004 | 10:43 PM
Actually, the only thing that would really bang your head up without a rollcage would be the window or door sill. And even then, I think a 5 point harness would hold you in the seat better, not protect your head.
If you have a rollcage, then you should also have padding on the bars that are close enough to come in contact with your head.
Just sharing what I've learned from HT.
Old Feb 14, 2004 | 06:55 AM
v4lu3s's Avatar
RTFM
a 5 point harness can also break your neck or compress your spine if installed to an all stock street car (most of em at least).
you need a HIGH mouning point for hte 2 straps going over your shoulders. in a racae car you are required to have a bar going across the car behind the seat and you use that to mount the top straps.
http://www.sfifoundation.com/seatbelt.html has good info abou proper installation. to quote a few parts:
If the upper attachment point falls significantly below the driver's shoulder, then a spinal compression injury is likely to occur. In an accident situation, the shoulder belts pull down and back on the torso as they resist the forward motion of the driver. The resultant restraint force compresses the spinal column and will add to the stresses in the spine already caused by the force of the crash impact.
On the other hand, if the trailing ends of the harness are too far above the shoulder (greater than 30°), then two problems can occur. First, tension in the shoulder harness is increased and undue stress is applied to the harness and its structural attachments. Second, excessive angle will cause excessive motion. If the harness belts are too far above the shoulder, they will provide little resistance to forward motion of the driver's upper torso. The result is impact with the steering wheel and the possibility of neck injury. The shoulder straps should also be 3-6" apart behind the driver's neck to prevent slippage off the shoulders.
Old Feb 14, 2004 | 06:56 AM
v4lu3s's Avatar
RTFM
and there is a reason all race bodies that require a roll cage/bar also require a helmet due to head injuries from placing a hard steel tube near your head...
Old Feb 14, 2004 | 10:57 AM
.bagged's Avatar
Default Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">and there is a reason all race bodies that require a roll cage/bar also require a helmet due to head injuries from placing a hard steel tube near your head...</TD></TR></TABLE>
I repeat..<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bagged93accord &raquo;</TD></TR><TR><TD CLASS="quote">
So how would a roll cage prevent your head from acting like a golf ball? You would still get tossed around roll cage or not..dont you think</TD></TR></TABLE>
Old Feb 19, 2004 | 06:02 PM
v4lu3s's Avatar
RTFM
the roll cage doesnt prevent it, it makes it worse. your head getting otssed around ios bad enough but when it gets bounced from steel tube to steel tube it tends to shatter like an egg.
Old Feb 19, 2004 | 06:22 PM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">the roll cage doesnt prevent it, it makes it worse. your head getting otssed around ios bad enough but when it gets bounced from steel tube to steel tube it tends to shatter like an egg.</TD></TR></TABLE>
not exaclty.
you have to think like this..with the roll bar/cage, your harness is mounit different, not much difference right? nope, harness on street car without a cage=break your neck
Old Feb 19, 2004 | 06:27 PM
v4lu3s's Avatar
RTFM
roll cage in a street car is stupid and in most places illegal. any self respecting track will throw you off without a helmet if you have a cage.
a harness and cage that is designed to protect you in a rollover is going to be close enough to your head (unless you ar elike 5'2") that you may hit your head against it.
sure hte harness is not gonna break your neck if it is installed right but that still doesnt make it safe.
Old Feb 19, 2004 | 07:18 PM
let the thread die.
Old Mar 2, 2004 | 04:09 AM
Shambro84's Avatar
hey man my buddy has a 2001 civic and we both live in illinois with a 5point harness and he hasnt been pulled over or told it was illegal or anything like that so id say its ok but still listen to all other replys you get.
Old Mar 2, 2004 | 08:36 AM
New User
Default Re: (Shambro84)
not real sure what you guys experiencer with a race car setup is but let me try to explain this a little better
in a street car without a roll cage or roll bar if you were to flip over with harnesses on the car would compress on top of you and the only movement yo would have is in the neck so :snap: it breaks your neck
with regular belts you are allowed roll forward or off to the side in such a situation aloowing you to bend at the torso
with a race car the cage is there because the chance of rolling over is multiplied 100 times and extremely violent
they require a helmet not only for the roll cage, but also for fire protection, and projectile projection. A small rock in the passenger floorboard of a car can become a missle when sugjected to extreme G forces
all race organizations require a certain density foam padding around all roll cage bars that could be hit by a human extremity , especially the head
also think about tthe different forces when wearing a harness, since the neck is the pivot point when getting hit in the side your head snaps left and right violently, a helmet helps it from beng so violent, hans devices and such further that help
so lets put it together as a big equation:
rollcage in car = 4 pt or higher harness and helmet always required
no roll cage = no harness should be installed
Old Mar 2, 2004 | 09:01 AM
.bagged's Avatar
Default Re: (urbanlegend21)
Thanks for the clarification
Old Mar 2, 2004 | 09:14 AM
Shambro84's Avatar
what part of illinois are you from man
im from ofallon il about 20 min from st louis
Old Mar 2, 2004 | 09:24 AM
-Bionic-'s Avatar
Former Sponsor
Default Re: (baGged93aCcord)
I'm sure there are a few people who want a 5pt harness with their momo seats, because it looks good. However, for those who wants those seats for practical reasons, what seats are compatible with regular seatbelts?
Thanks
4drferio
Jun 18, 2007 08:03 PM
pinoyk20
Honda S2000
30
Jun 11, 2007 09:20 AM
keprunited8
Mar 26, 2005 02:16 PM
justin 17
22
Jul 13, 2004 04:18 AM
EM2MoNsTeR
16
Jan 20, 2004 02:30 PM
