My Engine Blew!!
Old Feb 11, 2004 | 09:13 PM
QuanKwan's Avatar
Default My Engine Blew!!
FYI about my car, my motor blew due to the Timing Belt snapped.
ATTENTION: DO NOT EVER USE INLINE PRO CAM GEARS! They are garbage! Basically it ate away and shredded my timing belt and finally it just gave up, and this was on a brand spankin new timing belt too, probably lasted for about 3 weeks.
Its currently getting fixed and stuff, just wanted to warn anyone who are changing their cam gears. Stay away from Inline Pro Products, it was a shock at first, since they are a respectable company, but not this time.
Just thought I'd share that info with you guys. I will try to get pics of the damaged belt and gears soon.
Anyone ever had any problems or even heard about these cam gears?
The work was professionally installed from the Master Tech at Honda, which I have complete confidence in his work, doubt about it.
As far as damaged, all 16 valves bent, the head is being sent to the machine.
I was using the stock belt, but was Brand Spankin New, had it on for about 3 weeks before it gave out on me.
Modified by QuanKwan at 3:19 PM 2/12/2004
Old Feb 11, 2004 | 09:25 PM
97 TYPE-R 312's Avatar
Default Re: My Engine Blew!! (QuanKwan)
I've seen cam gears slip plenty of times in the past. We used to replace the adjusting bolts with high grade piecesthat wouldn't slip. This was back with AEM gears were about the only choice.
-Victor
Old Feb 11, 2004 | 09:28 PM
Bbasso's Avatar
*just asking*
Who did the install ?
maybe there was something overlooked??
Old Feb 11, 2004 | 09:38 PM
B2FiNiTY's Avatar
Default Re: My Engine Blew!! (97 TYPE-R 312)
wow... that is horrible. How bad was the damage? At what rpm?
Old Feb 11, 2004 | 09:46 PM
baonest's Avatar
Default Re: My Engine Blew!! (B2FiNiTY)
what kind of cams? timing belt?
what kind of motor?
Old Feb 11, 2004 | 10:23 PM
itr1244's Avatar
shtz.. sorry bro.
Old Feb 11, 2004 | 10:29 PM
Incognito's Avatar
Default Re: My Engine Blew!! (itr1244)
Gotta get the Toda cam gears. They are light, and the bolts actually hold.
Old Feb 11, 2004 | 11:21 PM
Chemicalviper's Avatar
Default Re: My Engine Blew!! (Incognito)
or skunk2, and str - these and toda are only ones i know for sure have worked perfectly
What was damage to the motor ? sorry to hear about it
Old Feb 11, 2004 | 11:39 PM
Eddiebx's Avatar
its possible that whoever installed it left the tension a bit too lose or something, that would cause it to shread and break too. I kinda find it hard for a cam gear to eat the belt that bad, unless they left the sprocket teeth like razor sharp or something, but who knows,
Old Feb 11, 2004 | 11:50 PM
b19coupe's Avatar
Sorry to hear it. Be sure that the gears are at fault before you condemn them, though. It is possible that installer error could be the cause. Best of luck with the rebuild
Old Feb 12, 2004 | 02:46 AM
Vitmn R's Avatar
Default Re: My Engine Blew!! (b19coupe)
Why are you flaming Inline Pro? I have known many Hondas that have left their shop completely bad*ss.. Also I will be working for Honda and my old roommate used to work on Hondas for 2 years.. It is not uncommon for the belts to rip and send the vavles into the pistons.. I am sorry for ur loss, but remember timing belt replacement is vital to those engines. By the way I have been seen thicker and stronger timing belts for Hondas, so you may want to consider that route as anything aftermarket will add stress on other parts.. Sorry if you get upset, but things happen for reason, I am neither defending Inline Pro, or blaming anyone.. As I have learned, Performance parts add stress to a factory not made to handle the extra stress!!! ALWAYS Replace any part that may be stressed beyond its limits. Just some food for thought.. Live and Learn RIGHT?!
Kevin
Old Feb 12, 2004 | 03:05 AM
uNF$@#!'s Avatar
Default Re: My Engine Blew!! (WANTED97ITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WANTED97ITR &raquo;</TD></TR><TR><TD CLASS="quote">Why are you flaming Inline Pro?
this is a no brainer.....b/c his motor fried and he thinks the cam gears are to do with it?
Old Feb 12, 2004 | 05:45 AM
quikB18B's Avatar
Default Re: My Engine Blew!! (Soup ****)
Who installed them? If it was a shop why not find out if they installed them incorrectly.
Like someone said Live and learn .
Old Feb 12, 2004 | 05:53 AM
Dave-ROR's Avatar
pics of the gears?
and why are people talking about bolts loosening? He said the gears destroyed the belt, not that they slipped.
I really wanna see pics of your gears cause right now I'm doubting they were really the cause...
Old Feb 12, 2004 | 06:25 AM
RTW DC2R's Avatar
Ive heard of cam gears eating timing belts, but not over a 3 week period. Sounds like installation problem to me, not a problem with the cam gears.
Old Feb 12, 2004 | 06:28 AM
Bradstard's Avatar
Time for an upgrade. This is the car gods telling you that your head wasn't good enough and you need to upgrade. They talk to me all the time...
Old Feb 12, 2004 | 06:34 AM
EEK's Avatar
EEK
Default Re: My Engine Blew!! (Fat Bradstard)
i didnt think of that..my friend has inline pro cam gears..they ate up his toda timing belt to shreds..inline put on the new belt after that..that belt was ate to shreds as well
Old Feb 12, 2004 | 06:47 AM
mist sITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by QuanKwan &raquo;</TD></TR><TR><TD CLASS="quote">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EEK &raquo;</TD></TR><TR><TD CLASS="quote">i didnt think of that..my friend has inline pro cam gears..they ate up his toda timing belt to shreds..inline put on the new belt after that..that belt was ate to shreds as well</TD></TR></TABLE>
that doesn't sound to good for inline pro products.
i wanna see pics of these gears.
Old Feb 12, 2004 | 08:58 AM
houston's Avatar
Default Re: My Engine Blew!! (mist sITR)
wow, now they do not only rip you off ... they make faulty ****!
I blame the owner of the car. When I install stuff. I monitor it. When you pay Jimbob the honda "Master Tech" he would rather your **** break.. IE more money for him. Jim Bob blames the gears.. you buy into ..etc etc.
DIY or DIE.. rich yuppie bastards.
Old Feb 12, 2004 | 09:04 AM
mikestypeR
Guest
Posts: n/a
Default Re: My Engine Blew!! (baonest)
sorry to hear that ...
timing beltz own all
92EG8
Nov 2, 2008 03:41 AM
-Championship-
Aug 5, 2006 09:06 PM
Si Shane
Jul 13, 2005 04:28 PM
Shizznaz
Nov 6, 2004 07:56 PM
Tomakit
Oct 26, 2001 02:40 PM
