2nd gear curse
Old Feb 11, 2004 | 06:59 PM
kseriesDC5's Avatar
Default 2nd gear curse
i know that the 2nd gear grinds... but does it grind while driving normally or hittin vtec? mines scratch on vtec.. i should try holdin down the clutch longer
Old Feb 11, 2004 | 09:58 PM
ZTYPE_S's Avatar
Default Re: 2nd gear curse (kseriesDC5)
second gear CURSE!!! ahh this car is a curse man! miss shifts, you name it. I have a 2003 S and that thing blew on me for over reving. geez!
Old Feb 11, 2004 | 10:02 PM
kseriesDC5's Avatar
Default Re: 2nd gear curse (ZTYPE_S)
whoa.. how many times did u over rev?
Old Feb 11, 2004 | 10:50 PM
ScuDC5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kseriesDC5 &raquo;</TD></TR><TR><TD CLASS="quote">i know that the 2nd gear grinds... but does it grind while driving normally or hittin vtec? mines scratch on vtec.. i should try holdin down the clutch longer</TD></TR></TABLE>
To answer your question, anytime. People tend to say it gets better as the car warms up, but it shouldn't really matter. I get more a "crunch" than a grind and as of late my 5th is "sticking" and won't shift out very easy. I have an 03.
As for over rev guy, human error, not mechanical... it's like calling your computer stupid, it only does what you tell it to.
Old Feb 11, 2004 | 10:57 PM
808 JDM EG6's Avatar
Default Re: 2nd gear curse (ScuDC5)
my 3rd gear is cursed. it sometimes doesn't want to let me drop it into 3rd while decellerating. now i noticed my clutch is making noise at idle in neutral with the pedal disengaged. i am gonna take it to the dealer and see if there is anything they can do about it. it is also making a noise and making it hard to go into gears intermittently.
Old Feb 11, 2004 | 11:02 PM
DC5ITR329's Avatar
Default Re: 2nd gear curse (JDMRSXWHORE)
I just had all the synchros done for the 3rd time. hopefully they can get it right
Old Feb 12, 2004 | 04:18 AM
GreenBean's Avatar
Default Re: 2nd gear curse (aznbo1626)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aznbo1626 &raquo;</TD></TR><TR><TD CLASS="quote">I just had all the synchros done for the 3rd time. hopefully they can get it right</TD></TR></TABLE>
What year is yours?
Old Feb 12, 2004 | 05:48 AM
blue03ep3si's Avatar
Default Re: 2nd gear curse (GreenBean)
I have probs with 1st thru 3rd gears every once in awhile too. It depends on my engine speed, how fast i'm going and how far i've got the clutch depressed. I get the 2nd gear kkrrr quite a bit, but i'm not worried about it yet...
Old Feb 12, 2004 | 06:02 AM
GreenBean's Avatar
Default Re: 2nd gear curse (blue03ep3si)
We all know that there is a bulletin on the 2003 RSX models for gear grinding and synchro replacement...
I spoke with Acura/Honda tech-line the other day and low-and-behold.............
Honda has asked for three 2003 RSX-S transmission for a "tear down and analysis"
(they have them now also) So they have found there are problems with the synchros in the 03's wich are the parts that were being used to repair the 02's....
I'll keep the DC5/EP3 forum posted when more news come down the pipes
Old Feb 12, 2004 | 02:07 PM
Eee Pee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreenBean &raquo;</TD></TR><TR><TD CLASS="quote">
I'll keep the DC5/EP3 forum posted when more news come down the pipes </TD></TR></TABLE>
Please do.
Old Feb 15, 2004 | 09:27 PM
TrueZen's Avatar
Right there with you Z, just got mine back with another engine, victim of a misshift? (raises hand)
Old Feb 15, 2004 | 11:01 PM
potator's Avatar
Since you own an DC5, I don't know if this will help much, but it seems a few EP3 owners had a second gear grinding/crunching problem as well. I'm not sure if they got Honda to put up a service bulletin for it, but a number of people were reporting the problem. HTH
Old Feb 16, 2004 | 05:53 AM
1337 Si's Avatar
Default Re: (potator)
Our 03 Si does the 2nd gear grind on high rpm shifts too.
Old Feb 16, 2004 | 10:36 AM
I am USDM's Avatar
Default Re: (Boosted Ego)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted Ego &raquo;</TD></TR><TR><TD CLASS="quote">Our 03 Si does the 2nd gear grind on high rpm shifts too.</TD></TR></TABLE>
mine doesnt :knock on wood:
btw i have 17k miles on my car...
Old Feb 16, 2004 | 04:52 PM
Essence of Chicken's Avatar
Go top off your transmission oil, then see if it still does it.
taakuumii!!
29
Aug 17, 2018 10:14 PM
an2ny888
Mar 1, 2004 01:04 PM
VTECLuDe96
Oct 8, 2003 08:09 PM
gsrteg93
Apr 30, 2003 11:07 AM
