car spudders and cuts off
i have a b series swapped eg...whenever i try to start it...it barely starts and the engine shakes like crazy and spudders and makes weird noises and cuts off
...im not really sure what to think or do...i still have some more diagnosing to do...any ideas?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMDC2 »</TD></TR><TR><TD CLASS="quote">Do you hear your fuel pump priming?</TD></TR></TABLE>
yes...nahh i dont have beez in yet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STN_Pat »</TD></TR><TR><TD CLASS="quote">obd2 motor switched obd1 ?</TD></TR></TABLE>
yes...obd2 clips/plugs on obd1 harness (dist., injectors, alt. etc.) chipped p28
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by otakueric »</TD></TR><TR><TD CLASS="quote">any check engline light?</TD></TR></TABLE>
none...thats the strange thing
okay...i just fixed it...
so i pulled the plugs (that were frekin 1 month old if that) and they were like flat burnt black colored and had some fuel on them and a strong fuel smell...so i pulled them out...turned the engine over for awhile (unplugged the ecu before turning it over) then put some brand new platinum plugs in (plugged the ecu back in)...turned it over and she runs great...stupid me for not checkin them first but i never would have thought they could be bad after a month if that.
He is right , if they are black you either have to much fuel or not enough spark I would figure it out, after all those great platinum plugs that you change regularly are worht the 3-6 dollars that you spend on each on isn't it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh »</TD></TR><TR><TD CLASS="quote">if they went bad like that after only 1 month, then there is something else wrong and the same thing will happen to your new plugs in another month...</TD></TR></TABLE>
yes i understand that...im in the process of burning a new chip to lean it out some to see if thats the problem. thanks
s0flyy56
Aug 6, 2008 08:34 PM
phreakywhiteboy
Mar 23, 2005 07:19 PM
