Can I Swap Suspension?
I have a 88dxcivichb. I wanna swap out mah hole suspension,control arms and everything. I was wundering if any oem honda/acura suspension will bolt up with the frame. I was thinkin about the 90-93 integra but i dont know if it will bolt it. HELP!!!
I know that the rear DA Integra suspension will bolt up with on the EF's, this is how most of us do the rear disc brake conversion. As far as the front suspension, I'm not positive, but I'm pretty sure that the DA Integra stuff will bolt up can someone clairify? Just wondering but why are you wanting to swap suspension?
i have 90-93 integra front knuckles on my 88 hatch along with the same year rear disks make sure you add the proportioning valve or the rear disks wont work right and may make you beake worse than stock.
on my 89 si i have 2000 civic si front knuckles and crx si rear trailing arms with 2000 si calipers and rotors 2000 si ebrake cables and 90-93 acura integra proportioning valve.
supdawg2
Aug 19, 2004 09:51 AM
Chris
Oct 16, 2002 04:19 AM
elusiveracing7
Apr 29, 2001 04:41 PM
