Need input on this oil cooler setup for my turbo
Old Feb 11, 2004 | 12:45 PM
Slammd Sol's Avatar
Default Need input on this oil cooler setup for my turbo
I plan on installing an oil cooler that is inline to my turbo and want to get some input on what you guys think. I am a little concerned about how it will flow because the oil cooler is sitting below the turbo on the stock AC mounts. Also the oil cooler is from a turbo volvo.
Old Feb 11, 2004 | 01:54 PM
Slammd Sol's Avatar
t t t
Old Feb 11, 2004 | 07:06 PM
CRXRageD's Avatar
Default Re: Need input on this oil cooler setup for my turbo (Slammd Sol)
It will cool oil. Personally, I wouldn't put it right in front of one the hottest areas on the car. You have the hot side right behind it. also, a really hot manifold. I hope you never intend to be at a stop cuz it'll probably heat soak.
Old Feb 12, 2004 | 04:15 AM
Slammd Sol's Avatar
bumpy
Old Feb 12, 2004 | 04:40 AM
yellowturbo's Avatar
dont put it in face of your turbo ...be logic ... try to tie-wrap it on the front face of your rad this way when your fan starts it will cool down your oil...
Old Feb 12, 2004 | 04:42 AM
stackz's Avatar
at the jetties fishin'
Community Builder
you need to at least turn that oil cooler on it's side or oil will pool up in it. Ford copcars from the 80's had a big problem with this and their oil coolers.
also, is that your oil return line poking out under the turbo? where the hell is that line going?
or is that a coolant line for the turbo?
Old Feb 12, 2004 | 05:06 AM
Muckman's Avatar
Moderator in Chief
Default Re: Need input on this oil cooler setup for my turbo (stackz)
I was gonna say vacuum line for the delta gate but that doesnt make any sense either. No clue
Old Feb 12, 2004 | 06:33 AM
IN VTEC's Avatar
I think an oil cooler for the turbo should be temperature regulated more than just throwing it on there. You'd need to run a thermostat, but since the routing is in series, that makes using a thermostat very difficult.
I think using an integrated oil cooler/radiator system is better, but a lot more expensive.
Old Feb 12, 2004 | 12:57 PM
Slammd Sol's Avatar
Humm.. I guess I'll put it sideways in the corner of the bumper under the headlight.. Should get some decent air flow there. Also, thats not my oil drain line, Its a coolant line for the turbo.
Old Feb 12, 2004 | 01:03 PM
rtype11's Avatar
just another idea, I run a lot of items in my front wheel wells, keeps room under the hood, jaut not maintenance items, you can run it flat on the plastic louvered wheel well, or maybe even bolt it perpendiclar to the outside or the frame rail, you already have some nutserts that will take an M8/M6 bolt.
Old Feb 12, 2004 | 01:10 PM
IN VTEC's Avatar
You could slap a fan on it and then manually or thermostatically turn the fan on.
Old Feb 12, 2004 | 01:16 PM
Slammd Sol's Avatar
Default Re: Need input on this oil cooler setup for my turbo (IN VTEC)
Humm.. another good idea
Old Feb 12, 2004 | 04:54 PM
JonnyCoupe's Avatar
You dont put oil coolers on turbo feeds, there simply not enough flowing oil to make it effective and if you cool it too much the oil gets thick and starts dragging your bearings and slows the turbo spool
The should be fitted on a sandwich plate from the filter. It cools all the oil going into the engine that way.
Old Feb 12, 2004 | 08:58 PM
platinum00's Avatar
Default Re: Need input on this oil cooler setup for my turbo (JonnyCoupe)
at what tempature will this accure.
i run the same setup here. the oil temps going into the turbo are ~100 when driving.
150 at light.
platinum.
Old Feb 12, 2004 | 10:14 PM
jonnybravo's Avatar
Default Re: Need input on this oil cooler setup for my turbo (jz)
So on a oil cooler like that, you should mount it sideways? The way shown is wrong?
Old Feb 12, 2004 | 10:27 PM
accordfreak's Avatar
Default Re: Need input on this oil cooler setup for my turbo (jonnybravo)
dude i have the same oil coooler from a volvo. i just haven't figured out what fittings it needs. when you get all your lines and fittings together please update. thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonnybravo &raquo;</TD></TR><TR><TD CLASS="quote">So on a oil cooler like that, you should mount it sideways? The way shown is wrong?</TD></TR></TABLE>
i'm wondering the same thing....
Old Feb 13, 2004 | 05:35 AM
IN VTEC's Avatar
Default Re: Need input on this oil cooler setup for my turbo (accordfreak)
The principal should be the same for all oil coolers. The discharge side of the cooler has to be oriented so that any air bubbles trapped in the cooler can escape out the discharge.
Fittings up or sideways with the discharge side up are the recommended orientations.
Old Feb 13, 2004 | 05:37 AM
platinum00's Avatar
i think mounting it the way it is would be fine. but im now worried about the oil going into the turbo being to cold.
something i never thought of
platinum.
Cee_mon
Nov 18, 2005 06:11 AM
CRXdan
Apr 4, 2005 06:28 PM
RACEPAK
May 25, 2004 09:07 AM
71 mgb
Nov 12, 2003 10:49 AM
