99 ex engine harness into 97 cx hatch?
Old Feb 11, 2004 | 12:24 PM
pootie.teng's Avatar
Default 99 ex engine harness into 97 cx hatch?
yo people i was wondering in order to make the swap easier without wiring problems can i just use a 99 civic ex engine harness in my 97 cx hatch. will this work. since the ex harness is already rigged for vtec.
Old Feb 11, 2004 | 01:23 PM
vtecb20coupe's Avatar
B A N N E D
Default Re: 99 ex engine harness into 97 cx hatch? (teckno_geek)
you can use it but will need the si obd2 ecu, unless you plan on converting to obd1.
Old Feb 11, 2004 | 02:12 PM
Default Re: 99 ex engine harness into 97 cx hatch? (vtecb20coupe)
yea i'm going to go obd1 p28 ecu. so it'll be cool and everything should plug up rite...
Old Feb 11, 2004 | 02:18 PM
95 LS's Avatar
Yeah but the 99 ex harness is obd2b. It would be less of a pain to use a 96-98obd2 ex harness instead of a 99-00 ex harness
Old Feb 12, 2004 | 01:16 AM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">yo people i was wondering in order to make the swap easier without wiring problems can i just use a 99 civic ex engine harness in my 97 cx hatch. will this work. since the ex harness is already rigged for vtec.</TD></TR></TABLE>
It will not work unless you want to do a decent amount of rewiring. Not only are the plugs slightly different but most of the pinouts are also. You need to reuse your stock harness or get a 96-98 EX harness.
jdm400
Jan 9, 2014 08:42 AM
b18bEKcoupe
Jan 16, 2008 02:04 PM
eeyore357
Jan 8, 2006 11:39 AM
pootie.teng
Feb 11, 2004 01:59 PM
