b18b1 swap into 99 hatch help
Old Jan 8, 2014 | 03:48 PM
jdm400's Avatar
Default b18b1 swap into 99 hatch help
Just want to verify I'm straight on my swap please. 99 obd2a b1 into my 99 obd2b ex hatch. Its installed and just want to check the wiring. Have original harness from my car and the p75 I pulled with the motor. Am I straight? I know about lengthening the sensors and have the dizzy plug. I also have a 99 crv harness i was told will work, has anyone else heard of this? Do I need an a to b jumper? Out of state working and would like to know so I can order one if needed and can finish when I get home. Thanks
Old Jan 8, 2014 | 05:11 PM
Runnerdown's Avatar
Default Re: b18b1 swap into 99 hatch help
You are right about everything. Use the original civic harness and modify as needed. For the ecu harness I would recommend xenocron. Btw what is a hatch ex, they only came as dx or cx?
http://www.xenocron.com/obd2b-to-obd...ess-p-172.html
Old Jan 9, 2014 | 05:37 AM
kyden's Avatar
you will need a harness adapter or a 99-01 crv distributor.
do you have an ex motor in it currently? there's no way you have an ex hatch.
Old Jan 9, 2014 | 08:42 AM
jdm400's Avatar
Thanks I got my answer and my bad it had a z6 is y I wrote that.
threehonda
Jul 26, 2010 10:33 AM
adamrich33
Mar 15, 2009 01:24 PM
pootie.teng
Feb 12, 2004 01:16 AM
pootie.teng
Feb 11, 2004 01:59 PM
