How to disable passenger side airbag?
I'm trying to disable the passenger airbag on my ITR. Is it enough just to pull the SRS 10A fuse in the fuse box to disable the whole system or can I unplug the passanger airbag alone. Where is that plug and how it looks like?
TIA
Eric
TIA
Eric
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soup **** »</TD></TR><TR><TD CLASS="quote">passenger airbag wont deploy if you remove the driver side airbag. the resistor in there will be a missing</TD></TR></TABLE>
Soup, can you be a lil more specific?
theres a yellow socket that you should have removed a plug from when you removed your driver side steering wheel. provided you did not plug in a resistor in its place, the passenger airbag wont fire (broken circuit)
redrelease
Nov 24, 2006 02:41 PM
