SOHC NON-VTEC ZC?
Old Feb 11, 2004 | 03:46 AM
Hybridize's Avatar
Default SOHC NON-VTEC ZC?
Does this engine exist? To my knowlege there is only the DOHC NON-VTEC and the SOHC VTEC ZC's. Also, I've read that you cannot swap D series heads onto the ZC blocks.
What's wierd is that a friend of mine recently had this engine swapped into his 2g civic. I have pics that I can post but unfortunatly the pics of the block stamp didn't show up. It's 100% a ZC block with what looks to be a CRX Si head and valvecover. There's no VTEC solenoid, so it's definitely not a VTEC head on there.
Is this a real Sohc non-VTEC ZC? If not, what heads can be swapped onto a ZC block?
TIA for any info.
Old Feb 12, 2004 | 01:21 PM
Hybridize's Avatar
Default Re: SOHC NON-VTEC ZC? (Hybridize)
Anyone with any ZC knowlege?
Old Feb 12, 2004 | 01:45 PM
0bd1_Kanobe's Avatar
This is possible.My friend swaped the dohc for his sohc si and the thing runs stronger than any dohc zc i have seen.But for the head transplant it is possible,also use a sohc vtec head to get a little higher compression ratio,hope this helps
HI-PER-HONDA 2004
Old Feb 14, 2004 | 08:09 PM
1point5CRX's Avatar
Default Re: SOHC NON-VTEC ZC? (BseriesHybrid)
yes theres sohc nonvtec zc engines, i have one
schwenk
Jul 17, 2007 08:22 AM
J-Spec EG
Nov 14, 2004 09:20 AM
dingusjt
Oct 2, 2003 08:54 AM
hondacivic4g
Aug 22, 2002 05:26 AM
daniel89civ
Mar 16, 2002 10:50 PM
