Fan wont turn on. Bad Relay?
Old Feb 10, 2004 | 10:41 PM
THE GAME IS THICK's Avatar
Default Fan wont turn on. Bad Relay?
When i run my car to normal operating temp. the fan doesnt turn on. When exactly is it supposed to turn on? Could it be a bad relay switch? I alredy checked the fuse box under the dash and they looked fine, i even replaced it just in case. thanks in advance.
-Brandon
Old Feb 11, 2004 | 12:23 AM
otakueric's Avatar
check the thermostat, and i had a problem with the o-ring that caused my fan to not turn on, check it
Old Feb 11, 2004 | 10:12 PM
Default Re: (otakueric)
thermostat checked out ok. any other suggestions? When is the fan supposed to turn on?
Old Feb 11, 2004 | 10:35 PM
dc2dragster's Avatar
From: eastside of the beach, westside of the coast, Long Beach, CA, usa
Default Re: (igotsol!)
did u check the fan switch? happen to me before.
Old Feb 11, 2004 | 11:07 PM
hatchii's Avatar
thermoswitch, replace it!
Old Feb 11, 2004 | 11:15 PM
otakueric's Avatar
Default Re: (hatchii)
it turns on after its warmed up on high idle
if the thermostat is ok, check to see if the valve is stuck at all?
Old Feb 12, 2004 | 04:08 PM
Combustion Contraption's Avatar
if you want to turn on your fan in the meantime, place a paperclip that jumps the two terminals on the plug that connects to your thermoswitch.
Shinwasha
Feb 17, 2012 07:50 AM
joebmx
Oct 6, 2008 10:56 AM
Eglifestyle
10
Mar 23, 2008 12:08 PM
The Destroyer
10
Apr 21, 2006 01:19 PM
turbo*s2k
Oct 28, 2003 08:05 AM
