Nitrous install-how to...?
does anyone have a nitrous install how to. i just need help with the wiring. i need to know which color goes to where. this is a NOS brand dry setup. i dont have any instructions what so ever and i have no idea where any of the wires go. any help or pics would be nice. thanks
Its only a simple relay. I dont know all the color/number labels but here goes. If you look on the relay youll see a schematic of the relay. The terminal marked 30 is the battery power. Across from it on the relay the other wire goes to the solenoids. The other 2 are the switching part of the relay. One gets ignition power and the other on goes to the arming switch then to the button/throttle swtich and finally to ground.
I hope this helps you if not at least you got a bump out of it.
Green 87
Red 86
30 black
85 white
White #85=Ground
Green#87=Feed Solenoids
Black#30=positive battery
Red#86=Mircro switch
hope that helps
Red 86
30 black
85 white
White #85=Ground
hope that helps
silverlude80
Nov 5, 2007 07:06 PM
