Nitrous install-how to...?
Old Feb 10, 2004 | 07:21 PM
tyflip2's Avatar
Default Nitrous install-how to...?
does anyone have a nitrous install how to. i just need help with the wiring. i need to know which color goes to where. this is a NOS brand dry setup. i dont have any instructions what so ever and i have no idea where any of the wires go. any help or pics would be nice. thanks
Old Feb 10, 2004 | 07:36 PM
tyflip2's Avatar
Default Re: Nitrous install-how to...? (tyflip2)
any links?
Old Feb 10, 2004 | 08:38 PM
tyflip2's Avatar
anybody?
Old Feb 10, 2004 | 08:46 PM
boostn420's Avatar
Its only a simple relay. I dont know all the color/number labels but here goes. If you look on the relay youll see a schematic of the relay. The terminal marked 30 is the battery power. Across from it on the relay the other wire goes to the solenoids. The other 2 are the switching part of the relay. One gets ignition power and the other on goes to the arming switch then to the button/throttle swtich and finally to ground.
I hope this helps you if not at least you got a bump out of it.
Old Feb 10, 2004 | 09:09 PM
tyflip2's Avatar
Default Re: Nitrous install-how to...? (boostn420)
that helps a little. thanks
Old Feb 10, 2004 | 09:18 PM
99blackcivicSi's Avatar
Green 87
Red 86
30 black
85 white
White #85=Ground
Green#87=Feed Solenoids
Black#30=positive battery
Red#86=Mircro switch
hope that helps
Old Feb 11, 2004 | 06:06 AM
tyflip2's Avatar
Default Re: Nitrous install-how to...? (99blackcivicSi)
yeah that helps but then which wire goes to the arming switch and which wire goes to the momentary switch
Old Feb 11, 2004 | 06:21 AM
red91sit's Avatar
you can run the arming switch in series with the wot microswitch.
thecivicsi
Apr 27, 2012 09:18 PM
fast-rex
Jul 5, 2004 02:30 PM
DruWO
May 21, 2004 04:59 AM
zCivic
Mar 3, 2004 11:31 AM
