cable to hyrdo conversion
Guest
Posts: n/a
I've heard that there is a kit that allows people with a cable tranny to use a hydro without having to install master/slave, hard lines etc. from my understanding it is a bracket that replaces the slave cylinder and lets the cable control the throw out fork. does anyone know anything about it, ie: who makes it, where to get it, what is needed (hydro flywheel, clutch?)
T.I.A
T.I.A
Try Hasport. Although they might only have the kit allowing cable clutch actuation in a newer hydro clutch chassis...
You could always do a gear swap too. That's what I ended up doing in my 91 Integra.
EDIT: As far as clutch stuff goes, you'll need a new disc if you do use a hydro transmission in your car (or a 92-93 cable LS)
Check out the HASport EFB2 kit: http://www.hasport.com/Product...2.htm
92integracer
Jul 26, 2007 02:48 PM
dlric
Oct 22, 2002 08:21 AM
