99-00 civic swap- o2 help
Ihave a 99 civic hatch. I also have a 99 SI swap. On the SI, the 2nd o2 sesor runs through the floor and plugs to the cat. The plug for the 2nd o2 is on my engine harness. Do I need to use the SI harness and pin the o2 to the ecu or use the HB wiring harness and make it fir the b16?
Thanks
Thanks
what ecu are u gonna use ? the 99 si? if so.. just use the si harness.. everything should plug up then. rite? or not?
on the hatch- .. is there not a wire that runs through the floor board? like on the si?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18coupe »</TD></TR><TR><TD CLASS="quote">everything should plug right in, that swap shouldn't be that hard</TD></TR></TABLE>
thats what i was thinking....
any updates?
any updates?
mjrage
23
Aug 16, 2004 10:12 AM
2000CX
15
Jan 29, 2004 06:57 AM
AGS
Jan 1, 2004 04:53 PM
