swap help see inside
Old 08-06-2002, 09:44 AM
PM-Performance's Avatar
Default swap help see inside
ok next weekend we are putting a b16 in my friends 99dx .
everythign is pretty straight forward, i guess he checked it already and it drops right in .
now for the harness. would it be easier to mod the stock harness or just put the si harness in with the si ecu?
thanks in advance
Old 08-06-2002, 09:55 AM
EEK
EEK's Avatar
Default Re: swap help see inside (itr206)
Si harness with Si ecu then its truely all plug and play
Old 08-06-2002, 10:04 AM
Default Re: swap help see inside (EEK)
actually its a 2000, sorry , but same thing though.
so go with the si ecu for ease ?
cool , thanks man , i appreciate it .
Old 08-06-2002, 10:26 AM
Jackson's Avatar
Make sure the motor is obd2 and has all the obd2 sensors. Also, the si harness is ideal for 99-00 civics, but it doesnt come with the secondary o2 attached to it. On the si's, the secondary o2 is located on the interior harness. If you run the si ecu, you will need to add this o2 sensor. You can look it up here.
Old 08-06-2002, 12:14 PM
Default Re: swap help see inside (Jackson)
thanks.
FWejCOUPE
11-27-2004 09:02 PM
ricebox
03-29-2004 08:12 AM
ekhatchb16
02-16-2004 04:39 PM
Ehron
08-01-2002 07:10 AM
Quick Reply: swap help see inside
