Stereo memory!!??
So i finally wired up my CD player. I gots 12 volts in 2 wires. A white/green and a white/blue wire. I connected the yellow Stereo wire to the white/green and the red wire to the white/blue. It works, but theres no memory, everytime i restart the car it resets memory. What should i do? Which wire is for memory?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mentat Ghola »</TD></TR><TR><TD CLASS="quote">so there should be a WIRE THAT PUTS OUT 12 VOLTS EVEN WITHOUT THE KEY IN THE IGNITION?</TD></TR></TABLE>
How else would the clock always have the right time ?
I would say switch the two power wires around you most likely have the constant and ignition wires mixed up. You could check them with a volt tester or even a ground light.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Balue3 »</TD></TR><TR><TD CLASS="quote">I would say switch the two power wires around you most likely have the constant and ignition wires mixed up. You could check them with a volt tester or even a ground light. </TD></TR></TABLE>
Bingo, got it workin ladies, thanx for the help.
6KAOS6
26
Feb 19, 2011 07:22 PM
sm00thk0zz
May 25, 2004 04:48 PM
