Emanage help
Old Feb 10, 2004 | 08:07 AM
95excoupe's Avatar
Default Emanage help
Just got done hooking up my emanage before the turbo goes on and it runs very odd the idle was surging and I have a flashing yellow light and a solid green light on the unit and when i drove it after like 1/4 throttle it just bogs really bad and it doesnt move...even without the turbo on it should still just drive normal right just run a little rich??? I checked all my connections too...please help
Modified by 95excoupe at 5:26 PM 2/10/2004
Old Feb 10, 2004 | 10:03 AM
95excoupe's Avatar
Default Re: Emanage help (95excoupe)
TTT...
Old Feb 10, 2004 | 10:27 AM
stackz's Avatar
at the jetties fishin'
Community Builder
if you completely hooked up the e-manage then IT will be controlling the fueling of the car now....
keep that in mind.
whatever settings the adjustment points on it came with from the factory...that's your new fuel curve and god only knows what it is so your fueling is probably all over the place.
the e-manage can be used for both boosted and N/A cars.
Old Feb 10, 2004 | 02:12 PM
95excoupe's Avatar
Default Re: Emanage help (stackz)
It came pre-tuned for the greddy kit and my motor, I just wasnt expecting it to run the way it did....I am still in the process of putting the turbo on so I guess theres no going back now.
Old Feb 14, 2004 | 11:21 AM
95excoupe's Avatar
Finally got the turbo on and it still bogs after 1/4 throttle and it wont go anywhere, I have a soild green for the most part and a flashing yellow light on the emanage sometimes itll switch over to orange on the active side but the interaction is always flashing yellow...PLEASE HELP my car is useless right now..thanks
Old Feb 14, 2004 | 11:27 AM
TheShodan's Avatar
Moderator
Honestly this is really where the tuning portion comes into play. GREDDY unfortuneately won't help that much.
Or call GODSPEED, they are E-manage exports
Godspeed Inc.
22783 Heslip
Novi, MI 48375
248.305.8140
TurboXS Approved Tuner with AWD Dyno Facility
Dynapack Dyno
http://www.godspeedinc.com
Old Feb 14, 2004 | 11:48 AM
95excoupe's Avatar
Default Re: Emanage help (TheShodan)
It is pretuned so it says... it bogs like crazy I cant drive it the way it is though...I unplugged the box and it runs ok like that just lean so I am thinking it might be a bad box???
Old Feb 14, 2004 | 12:04 PM
streetlvlhatch's Avatar
your emanage is showing a trouble code since the light is flashing. You can look how to read it on mohdparts.com or in the manual. I would try that and see what the problem is.
Old Feb 14, 2004 | 04:49 PM
95excoupe's Avatar
Default Re: Emanage help (streetlvlhatch)
Its not a red light on the active side that is orange till i hit the throttle then it is green till i let off the interaction light is the one thats flashing so I cant grab a code or anything off it...for anyone that hooked this up I noticed some conflicting wiring diagrams.. the one from the emange book i found online and the one from the instructions are different. It says on one to use a12 for the injector ground then on the emanage instructions it says use a25 cause this be my problem????
Old Feb 14, 2004 | 08:07 PM
jaymes2030's Avatar
The interaction light flashing all the time is normal. The green light turning orange is also normal (it turns orange when you cross the preset tuning point). Check out mohdparts.com and subscribe to the emange yahoo group. Tons of info there.
Old Feb 15, 2004 | 10:11 AM
95excoupe's Avatar
Default Re: Emanage help (jaymes2030)
Figured it out I had the map in and outs switched runs good nice and quick now...anyone know any good emanage tuners in NJ?
b16excoupe
May 19, 2013 05:57 AM
mike93eh
Mar 9, 2005 08:30 PM
Integra99GSR
Dec 4, 2003 02:52 PM
TurboLude00
Nov 1, 2002 10:13 AM
