95 Hatch Si w/ B18C1 swap...Idle Probelm...Need help quick!
Here is the story. I have a 95 Hatch Si, with an OBD II GSR swap done to it. A little time after the swap my car started to idel all messed up. It goes from about 800 then raises up to about 1800 continuesly. I bought a new TPS and put it on, and it still does it. i am running a chipped P28 ECU, could that be a problem? I really want to fix this B.S. it is strated to get old fast. Any help would greatly be appreicated.
Joshua
Joshua
Check map sensor, tps, idle air control valve, and make sure IAT and other sensors aren't switched. Even check for loose ground wires. Have you tried using a different computer just to check if that was the problem? Try cleaning all the sensors, etc. Good luck.
sixtoek
Apr 25, 2013 05:38 PM
PDXHatchback
Feb 10, 2004 10:16 AM
PDXHatchback
Dec 12, 2003 07:09 AM
