Headlight reccomendations for a '93 Civic
Old Feb 9, 2004 | 11:44 AM
mab2's Avatar
Default Headlight reccomendations for a '93 Civic
The headlights (assembly, not the bulbs) in my 93 coupe were replaced a couple times before I got the car, and i'd like to replace them with something better.
Are there any decent aftermarket headlights for my car? I am not interested in ricing it up, I just want something better than what I have now, as well as something that isn't too expensive. Can it be done? Or should I just go OEM?
Old Feb 9, 2004 | 11:46 AM
hybridreams's Avatar
Default Re: Headlight reccomendations for a '93 Civic (mab2)
Stick with OEM and a better bulb.
I used to think my projectors looked nice until everyone that rode in my car kept on asking me at night if I had my headlights on.
Old Feb 9, 2004 | 11:48 AM
JDM-EJ1's Avatar
Default Re: Headlight reccomendations for a '93 Civic (hybridreams)
Exaclty, projectors look really good, but their dim as ****... I have my OEM with the Xenon bulbs in them, work great.
Old Feb 9, 2004 | 11:55 AM
mab2's Avatar
Thanks for the quick responces... is there a certain bulb I should use?
Old Feb 9, 2004 | 12:10 PM
AmginE's Avatar
Default Re: (mab2)
i just installed a set yesterday.
Compared to my OEM, (which were slightly broken, so they weren't shining completely right) they shine probably 50-60% better, easily. Even with the stock bulbs i am using.
Old Feb 9, 2004 | 12:13 PM
POE's Avatar
POE
i would just save your money for somthing beeter and keep the OEM headlights and just get better bulbs !
Old Feb 9, 2004 | 12:16 PM
ntensehonda's Avatar
Default Re: (Vtecin94dx)
JDM with city lights!
Old Feb 9, 2004 | 12:37 PM
b16ahybrid's Avatar
Default Re: (ntensehonda)
Don't get any colored bulbs, sylvania silverstars in my truck and it's a nice improvement over stock. Im my car i'm runing koito white beams and they are like the silverstars but brighter, The silverstars are i believe 55/65 watt while the koito's are 80/100 watt..if they made the koito's in 9007 i'd have them in my truck too. I've had those for almost 4 years now and have not had to replace them once, unlike the piaa's that i had to replace every 3-4 months....i don't like piaa's
Old Feb 9, 2004 | 03:03 PM
Blacklightning's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ntensehonda &raquo;</TD></TR><TR><TD CLASS="quote">JDM with city lights!</TD></TR></TABLE>
give me a brake!!!! JDM Yo
If you are willing to put some work into projectors, they can turn out pretty good. My friends can't believe that I have 55W stock bulbs in my projectors.
If you ues the wire kit, change the grounds, and stick with stock bulbs or higher watt stock bulb. They can be ok, not great, but better than stock.
Denji are ok, but TYC's are better. From what I've seen DO NOT buy any other projector. IMO.
Stock ones and the ones above are good also. Rocking the Stock ones are your best bet.
Old Feb 9, 2004 | 03:09 PM
Tad's Avatar
Tad
just get stock headlights or jdm ones.
yes there is a reason for the jdm,
usdm lights have glass nubs sticking out of them(3 per light), the jdm ones are comletely flush, for a slightly sleeker look.
and get some silvania silverstars bulbs,
or buy a bunch of superwhite xenon bulbs and replace htem when they blow out. if you get some good ones each bulb should last at least a year.
might be cheap, but it works,
and is alot brigther than stock
Old Feb 9, 2004 | 04:06 PM
ej1 pilot's Avatar
i think these are pretty tight, thinking of buyin a pair myself if you have a red x heres the link http://www.robearracing.com/pd...e.cfm
Old Feb 9, 2004 | 04:16 PM
Fuster_Cluck's Avatar
Default Re: (AmginE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AmginE &raquo;</TD></TR><TR><TD CLASS="quote">
Compared to my OEM, (which were slightly broken, so they weren't shining completely right) they shine probably 50-60% better, easily. Even with the stock bulbs i am using. </TD></TR></TABLE>
I have these on my hatch. I bought them in hope for improved lighting but I think they have failed me. In the rain I can't see $hit still and this is with OEM bulbs none of those super white $hit! Since they are not performing to my expectations I am going to see if one of the local ricers will give me there OEM's + $100 for them. I still have my OEM's which I need to take apart, clean the lens really well, and paint the inside black. $100 in my pocket sounds good
Maybe it's the set I have
I've had projectors and they sucked a$$!!!!!!
Old Feb 9, 2004 | 04:20 PM
Soccerking3000's Avatar
Default Re: (Hybrid93Hatch)
i have projectors with PIAA bulbs and they are birght as hell so uddo what u guys are sayin
Old Feb 9, 2004 | 04:24 PM
MikeNice's Avatar
You should take a look at the one peice Halo's dark housing or the JDM joints with city lights.
Old Feb 9, 2004 | 04:27 PM
moondoggy's Avatar
Default Re: (Soccerking3000)
i had denji projectors a while back. they're not terribly bad but they're really dim. i'm also trying to con some ricers into buying them
right now i'm rocking oem with jdm corners which i traded for. the corners looks nice on pics but way! nicer in real life. so clear, so bright, so damn nice
u can also go stock with vision corners.....they're pretty cheap and pretty nice looking too.
in terms of bulbs, silverstars are probably the best for it's $$$
Old Feb 9, 2004 | 05:10 PM
Ricey McRicerton's Avatar
Default Re: (moondoggy)
TYCs. If I had to go with something other than OEM in an EG, it would be the TYCs with the GE 9003sb bulbs from Wal Mart. The bulbs are awesome. Under 15 dollars for the pack and they give off bright white light and have lasted me over a year now.
Old Feb 9, 2004 | 05:17 PM
Archidictus's Avatar
Unceasing Measure
Default Re: (Ricey McRicerton)
TYC one-piece headlamps kick ***. The cutoff is sick, they're way brighter, the spread is awesome and they look infinitly better. I've got some black housings on my red hatchy (stupid F250 running over my car ) and I love em.
Old Feb 9, 2004 | 05:22 PM
Caveman74's Avatar
Default Re: (Archidictus)
If you want better and brighter bulbs bet some 80/100 or higher. I have silverstars and I'm not too impressed. It still is the same wattage, but just a whiter light. Go xenon or get a higher wattage bulb
Old Feb 9, 2004 | 05:30 PM
H22A EG6's Avatar
Default Re: (Caveman74)
go wit these
Old Feb 9, 2004 | 05:36 PM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">TYC one-piece headlamps kick ***. The cutoff is sick, they're way brighter, the spread is awesome and they look infinitly better.</TD></TR></TABLE>
I agree. His TYC headlights are awesome. I highly recomend them for function and fassion. I will be getting them for my car and will be doing a retro fit into them.
Old Feb 9, 2004 | 06:40 PM
Civicboy's Avatar
I loved mine!! I also had Raybrig bulbs, but I loved them!
Old Feb 9, 2004 | 07:02 PM
AmginE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Hatch &raquo;</TD></TR><TR><TD CLASS="quote">
I've had projectors and they sucked a$$!!!!!!</TD></TR></TABLE>
well, that sucks. They work excellent for me, project as well as my mom's suburban (for comparison purposes) and better than the wife's 2001 cavalier..
Old Feb 9, 2004 | 07:05 PM
LSVTECoupe's Avatar
i have the jdm headlights with the city light, they shined about 50% better than the US one, and thats with the factory bulb they came with, plus they fit better and look nicer.
Old Feb 9, 2004 | 07:06 PM
Nader_D's Avatar
Default Re: (LSVTECoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTECoupe &raquo;</TD></TR><TR><TD CLASS="quote">i have the jdm headlights with the city light, they shined about 50% better than the US one, and thats with the factory bulb they came with, plus they fit better and look nicer.</TD></TR></TABLE>
sweet thats good to hear! my money is sent out tomorrow for my jdm headlights + corners :D
Outrun
10
May 23, 2020 10:46 PM
KhornLuda
Feb 23, 2013 06:45 AM
jeremyrocksursox
Nov 27, 2008 09:35 PM
RTW DC2R
Feb 25, 2008 07:57 PM
RedGSR
Jun 6, 2004 09:39 PM
