boosted b20b ?....what do you think
Old Feb 9, 2004 | 09:36 AM
819turbo's Avatar
Default boosted b20b ?....what do you think
do you think this is ganna be rialable?i'm building a 8psi b20b on stock internes. here my setup:
- t25 ( from a talon)
- custom intercooler
- custom exhaust manifol and 3" donwpipe
- reprogramed ECU (program for a b18b with a t3/t4 with 450cc injectors an 8.5:1)
- 440cc injectors
- SMC plus
- master boost timer
if you think this is ganna blow please help me make this block stronger.
Old Feb 9, 2004 | 09:50 AM
SIK IN DA HED's Avatar
New User
Default Re: boosted b20b ?....what do you think (819turbo)
if you keep it at a moderate psi level, you wont need to build your motor to boost it.
Old Feb 9, 2004 | 10:10 AM
819turbo's Avatar
the reason i asked is that i've been hearing alot on the fact that the b20b only as 7mm of sleeve (i knew that part) (compared to a b18b that as 9mm) an that makes it unrialable. but i thought that at 8 psi there would be no problem.
Old Feb 9, 2004 | 12:14 PM
819turbo's Avatar
oh yeah forgot to say that i have a walbro 255 fuel pump
93 Eg Couper
Dec 13, 2008 11:47 AM
hany
Nov 21, 2006 12:09 AM
4cylsturbo
Apr 27, 2006 03:27 PM
Talon12bp
Feb 8, 2004 11:01 AM
Sohc Driver
Apr 3, 2003 01:15 PM
