Balljoint boots...?
I am going to be removing my trans soon, and i know that you have to remove the ball joints. I think we are using a fork, so i want to get the replacement parts now before i do it. What parts do i need, i was told i need 4 boots total? Upper and lower ball joints boots, right? thats it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JV »</TD></TR><TR><TD CLASS="quote">Are you really that bored? Lower ball joint / tie rod boots for the 25th time.
BTW: These will tear if you use a fork type balljoint/tie rod separator</TD></TR></TABLE>
Go to work!! or something
I suggestyou just follow the advise I post up in almost all other axle removing thread and just not separate the ball joints. just disconnect your controll arms and you can swing it out enough to remove the axles.
squeaky
14
Aug 29, 2004 12:08 PM
