filter over HKS SSQ
when i was tech inspecting SSCA pro rally there was alot of high end "open" car that had a filter over there HKS BOV. i was told this is to keep dirt out has anyone on the road had a problem with not putting a filter over there BOV i do not have one oh my HKS but it is also mounted up high.
Any thoughts would be good.
some say that some air gets in the bov under vac conditions so really don't know if i should be worried or not. i have the HSK SSQ so i don't know if i should be worried or not.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JrCRXHF »</TD></TR><TR><TD CLASS="quote">
some say that some air gets in the bov under vac conditions so really don't know if i should be worried or not. i have the HSK SSQ so i don't know if i should be worried or not.</TD></TR></TABLE>
i wanted a picture or the SSQ with a filter
yeah the SSQV is designed so it stays shut at VAC., so it's not really needed. What you could do if you are worried about it is get the recirculation kit, and run it back to the intake pipe between the air filter and compressor wheel.
