O2 Sensor problems...
Old Feb 8, 2004 | 10:36 AM
clutch33's Avatar
Default O2 Sensor problems...
I spliced into my o2 sensor for my air/fuel gauge and everything was working great for a couple months, then the other day in the rain the car started to stall and the check engine light came on. I got a primary heated o2 sensor code. Now the car is hesitant and the air/fuel gauge is acting wierd. Do I need a new O2 sensor or what do I need to do?? PLease help...
Old Feb 8, 2004 | 11:01 AM
STIBungy's Avatar
Check your connections. It'd be best to solder the connections and then cover them from the elements using heat shrink or something.
Old Feb 8, 2004 | 11:53 AM
AzG35's Avatar
Default Re: (B18CBungy)
Reset the ECU, run the car and see if it continues. If it does, you will most likely have to replace the O2
dohdoh420
Oct 23, 2006 07:52 PM
Lude_with_an_H22_Attitude
Nov 3, 2005 02:22 PM
EGCivicCoupe
Apr 5, 2005 07:36 PM
TURBODC4TEG
Dec 19, 2004 07:32 PM
quikrpm'z
Oct 10, 2001 06:15 AM
