Misfire
I was running my car at the track and I got a CEL light. The light indicated cyl 3 misfired. I was squeezing 65 shots at the time and I am wondering what could be the potential causes of the misfiring? When I reset the ECU, the CEL goes away and does not come back on.
This isn't my first time getting a CEL when squeezing. I was getting a CEL when I was running 75 shots and then backed it down to 65 shots. I didn't check the CEL when I was running 75 shots. I ran twice last night...my first run was 15.3@90mph and second one was 15.4@88 mph. My second run was when I got the misfire CEL.
try two degree colder plugs, and maybe higher octane fuel. I know some 5th gens have a problem with having misfires that never show up again, mine did and there was a factory recall for it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drag-On23 »</TD></TR><TR><TD CLASS="quote">I ran twice last night...my first run was 15.3@90mph and second one was 15.4@88 mph. My second run was when I got the misfire CEL.</TD></TR></TABLE>
Bah. Still low 15s. Man, Accords suck for power.
Did you run with your 18s on? Was the spare, and jack still in the car?
Also, how's the car feel with that LT torque converter? How much did that you run you if you don't mind me asking?
I was running with 18s but without the spare and jack. I have to run with the 18s because I need tires that grip. I lose traction even with 65 shots and I lost even more traction with 75 shots even on Yoko Pradas. If I was running lighter wheels, stickier tires, 75 shots, without my amps and my backseats, I will be able to run better times.
The LT TQ converter costed me around 700 for the rebuild and the part.
a miss could be causes by a lot of things a dead or weak injector, fouled plug a bad wire a bad valve. I would start by checking for spark and injector pulse if it has spark and the injector is firing check compression
kaotikvizion
Jun 3, 2008 11:19 PM
