Swaping SOHC, stay with stock d16z6, or should i mini-me??
Old Feb 7, 2004 | 11:48 PM
Nerologic's Avatar
Default Swaping SOHC, stay with stock d16z6, or should i mini-me??
im going to blow my almost blown d16z6 at the track this weekend with a 100 or 120 shot so i need to put in another engine. I have to chocies put a d16z6 together that i have thats apart or should i min-me it? I have access to a 93 DX engine (d15b) and i know i can get it for almost free. Should i just stick with what works and stay with a z6? or is there a bit more power with the mini-me? and if i mini-me it will it be unreliable like teh mini-me i had in my EF???
Old Feb 8, 2004 | 12:09 AM
eg6ajk's Avatar
Default Re: Swaping SOHC, stay with stock d16z6, or should i mini-me?? (Nerologic)
d15b mini me vs z6:
-same hp but slightly less torque on the d15b
-weaksause d15b rods
-more work and time then its worth
overall I would personally stick with the d16z6 its pretty sturdy and reliable block that can take a beating.
Old Feb 8, 2004 | 12:18 AM
D16Z6racing's Avatar
Default Re: Swaping SOHC, stay with stock d16z6, or should i mini-me?? (eg6ajk)
Look at my name and signature. NufSaid.
Plus I'm not getting into how many times this has been talked about.
https://honda-tech.com/zerosearch
Old Feb 8, 2004 | 08:45 AM
Nerologic's Avatar
i already searched, i got pages on how-to's on mini-me's but i never saw any that delt with "d16z6 vs. mini-me" and so on...
Old Feb 8, 2004 | 10:32 AM
lohatch's Avatar
run the Z6, more parts available than for the B7 such as rods.
Old Feb 8, 2004 | 11:09 PM
Nerologic's Avatar
Default Re: Swaping SOHC, stay with stock d16z6, or should i mini-me?? (lohatch)
(same response as one i made in my blown motor post)
Im building a Z6 now (i ditched the mini-me deal) as we speak i already got the pistons i just need them pressed on the z6 rods and then im putting them in the block. I am going to use stock z6 block and rods with p29 pistons that i got from the local yard. As for the head i might smoth it out and polish the exhaust ports "as seen on The Old One's site." Manifold wise i am just going to run a y8 with obd1 injectors and ls TB. Only problem im running into is i dont know if i will have enough clearence with a stock z6 gasket. The comp. calc. gives me like 13.5 or something above 12. And if i clay, i will only get regular valve clearence, not the valve clearence with the vtec lobes. So im stuck on that as we speak, or does anyone know how to clay a motor with the vtec lobe? i was thinking just to hook up a bat to the vtec solinoid to activate it and just spin the crank with clay inside, but i dont know if this will work..so anyone have any ideas???
Old Feb 8, 2004 | 11:11 PM
Civic Hx-T's Avatar
Mini-Me is alot of work.
Generally... you do a mini-me ( I believe ) if you already have a DX/CX/VX/LX bottom end in your car and don't want to pull it.
Go z6 ... :D Unless you can find an HX motor. MUAHAHAHAHA>
Old Feb 9, 2004 | 12:02 AM
kingSfit's Avatar
Default Re: Swaping SOHC, stay with stock d16z6, or should i mini-me?? (D16Z6racing)
as what it says under this
Old Feb 9, 2004 | 08:47 AM
Nerologic's Avatar
i just spoke to some one that said i couldnt run PM7 pistons in a stock d16z6, can anyone verify this??
Old Feb 9, 2004 | 05:57 PM
Civic Hx-T's Avatar
I'm not sure what pm7's are... specifically..
but if they came out of another D or B series motor, most do fit in a z6. Like LS's fit in a z6 but have to have some work done to do so.
Old Feb 9, 2004 | 06:06 PM
HXvtec's Avatar
Default Re: (Civic Hx-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic Hx-T &raquo;</TD></TR><TR><TD CLASS="quote">Mini-Me is alot of work.
Go z6 ... :D Unless you can find an HX motor. MUAHAHAHAHA&gt;</TD></TR></TABLE>
yes forget the Z6 and put a Y5 in that biatch.
Old Feb 9, 2004 | 06:20 PM
Civic Hx-T's Avatar
w00t!
The takeover!
Old Feb 9, 2004 | 09:02 PM
Nerologic's Avatar
pm7's are ZC pistons...p29 are 89 integ pistons
Old Feb 9, 2004 | 09:06 PM
MikeNice's Avatar
Stay with the z6. Cheap isn't always better.
With a 120 shot your not even going to enjoy your first run because you probably blow your motor before you get out of 1st gear.
Old Feb 10, 2004 | 10:21 PM
Nerologic's Avatar
ya i already know what im going to do, just put in the pm7's in the d16z6 and see what happends
Old Feb 11, 2004 | 01:17 AM
civic duty's Avatar
Default Re: (HXvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HXvtec &raquo;</TD></TR><TR><TD CLASS="quote">yes forget the Z6 and put a Y5 in that biatch.</TD></TR></TABLE>
This is my suggestion to everyone who wants to swap to a d-series.
Old Feb 11, 2004 | 05:05 AM
sohcvtec1995's Avatar
Default Re: (civic duty)
z6 all the way
Old Feb 11, 2004 | 05:37 AM
mafioso102's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic duty &raquo;</TD></TR><TR><TD CLASS="quote">This is my suggestion to everyone who wants to swap to a d-series. </TD></TR></TABLE>
Why is this? I have heard a lot of theory behind the benefis of the hx...but as of yet (sans turbo) i have yet to see any dyno's proving that they hx is superior to the z6 or y8.
Old Feb 11, 2004 | 07:46 AM
Nerologic's Avatar
ya i was reading a post earlier about the HX was superior, but most of the post showed how the HX wasnt really superior becasue it had the bigger lobes...
93eghb
Feb 17, 2008 11:44 AM
kin413
Jun 18, 2007 11:48 AM
dr_latino999
Jul 30, 2006 09:01 AM
Limited S.L.I.P.
Nov 3, 2003 08:42 AM
buskethead
May 20, 2003 04:02 PM
