CTR vs. ITR 5lug conversion?
Old Feb 7, 2004 | 10:23 PM
Phase2's Avatar
Default CTR vs. ITR 5lug conversion?
hello guys.
i have a 2000 Civic CX hatch, and i am planning on doing a 5lug conversion...
i was wondering if you can tell me the differences were between a Civic Type-R conversion and a ITR conversion.
thanks.
Old Feb 7, 2004 | 11:37 PM
Kidnkorner's Avatar
Default Re: CTR vs. ITR 5lug conversion? (Phase2)
depends on the years i know the 96 civic type r was 4x114.3 but the 99-00 is 5x100, and the ITR is 5x114.3. i am basing my info off of other retailers products on thier web sites
Old Feb 7, 2004 | 11:53 PM
eg6ajk's Avatar
JDM ITR 96-7 specs R 4x114.3 same sized brakes - 15" wheels
USDM/JDM ITR/CTR 97-01 5x114.3 used standard Civic/Integra axles (32mm) - 15" wheels
JDM ITR 98-01 SpecR 5x114.3 (rear identical to above), front used 36mm axles nuts and specific axles (outers joint) - wheels were also 16"
for ease of maintnace the USDM ITR and JDM CTR would be the way to go. no need to deal with special axles or bearings. 96 spec setup IMHO is not worth the money, better to stick with the GSR/Si setup which offers same brake size with less hassles (ie rotors)
Old Feb 8, 2004 | 12:15 AM
Phase2's Avatar
Default Re: CTR vs. ITR 5lug conversion? (eg6ajk)
so the ITR suspenion (5-lug) is identical to the CTR suspension?
Old Feb 8, 2004 | 01:42 PM
Phase2's Avatar
up
Old Feb 8, 2004 | 02:46 PM
ill phil's Avatar
The US ITR 5-Lug is the same as CTR 5-Lug except for the rear LCA's I beleive. The JDM 5-Lug is slightly different as mentioned above. If you re-read the detailed explanation from eg6ajk you'll see that.
Old Feb 8, 2004 | 09:02 PM
Phase2's Avatar
Default Re: CTR vs. ITR 5lug conversion? (ill phil)
anything else different (suspension wise) such as the control arms?
Old Feb 8, 2004 | 09:11 PM
92b16vx's Avatar
Default Re: CTR vs. ITR 5lug conversion? (Huggy Bear)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Huggy Bear &raquo;</TD></TR><TR><TD CLASS="quote">depends on the years i know the 96 civic type r was 4x114.3 but the 99-00 is 5x100, and the ITR is 5x114.3. i am basing my info off of other retailers products on thier web sites</TD></TR></TABLE>
All CTRs were five lug, and the early ITRs were four lug.
Old Feb 8, 2004 | 09:27 PM
AL ASPIRATED's Avatar
i heard that the ctr 5 lugs needs to use only ctr axels and cannot use any of the US b series axels.
correct me if im wrong.
i have jus heard this
Old Feb 8, 2004 | 10:22 PM
chameleon's Avatar
Default Re: (AL ASPIRATED)
just to add some info..
98+ JDM ITR 5lug with 36mm axle nuts use 97+ prelude axles, they are the same thing as B series 32mm inner and 36mm outer doh. so no need for special axles.
Old Feb 10, 2004 | 12:06 PM
ill phil's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AL ASPIRATED &raquo;</TD></TR><TR><TD CLASS="quote">i heard that the ctr 5 lugs needs to use only ctr axels and cannot use any of the US b series axels.
i have jus heard this</TD></TR></TABLE>
Same as US ITR so incorrect. Should accept B-series axles fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phase2 &raquo;</TD></TR><TR><TD CLASS="quote">anything else different (suspension wise) such as the control arms?</TD></TR></TABLE>
LIke I said, the rear lower control arms (LCA's) differ between ITR/CTR.
Old Feb 12, 2006 | 11:17 PM
DC4KiD's Avatar
Default Re: (ill phil)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ill phil &raquo;</TD></TR><TR><TD CLASS="quote">
LIke I said, the rear lower control arms (LCA's) differ between ITR/CTR.</TD></TR></TABLE>
So if i were to keep my current rear control arms (on my 96 integra) and just swap out the 4lug hubs for the ctr 5lug hubs, i should be fine? im just making sure before i buy anything.
Old Feb 13, 2006 | 12:24 AM
BlueIntegraBoy's Avatar
Default Re: (DC4KiD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC4KiD &raquo;</TD></TR><TR><TD CLASS="quote">
So if i were to keep my current rear control arms (on my 96 integra) and just swap out the 4lug hubs for the ctr 5lug hubs, i should be fine? im just making sure before i buy anything. </TD></TR></TABLE>
Yup
Old Feb 13, 2006 | 01:37 PM
DC4KiD's Avatar
Default Re: (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">
Yup</TD></TR></TABLE>Cool thanks!
Old Apr 24, 2007 | 03:13 PM
TonyO's Avatar
Sorry to bring up such an old thread, but here is my situation, and i was wondering if you HT guys can give me a hand.
I have a 2000 Si(Ex in US), and i plan to do a 5 lug off a 98 USDM ITR. I've been told this is not a direct bolt on. Would the axles off the ITR bolt right in, or would I need different ones? What is different off the ITR that I would need to bolt into the EK? Thanks in advance for the help guys.
Old Apr 24, 2007 | 09:59 PM
TonyO's Avatar
Default Re: (TonyO)
Bump for some answers.
Old Apr 24, 2007 | 10:09 PM
92hatchboi's Avatar
Default Re: (TonyO)
the axles will bolt right on. shouldnt have a problem with the fronts
Old Apr 25, 2007 | 11:06 AM
TonyO's Avatar
Default Re: (JJSpecTuning)
haha someone brought this back from 2006
Thanks for the replies guys.
SPOON_BeIgHtEeNsEe
Feb 13, 2006 02:46 PM
Si_Guy2000
Suspension & Brakes
12
Jan 7, 2006 12:24 PM
Uneekpinoysk8er
Dec 25, 2004 08:27 PM
ILOVEGIRLS
Oct 18, 2003 12:20 PM
mini-cRx
Aug 24, 2003 05:06 PM
