94 gsr into 99 gsr?
Old Feb 7, 2004 | 09:58 PM
hallsy's Avatar
Default 94 gsr into 99 gsr?
Hey I just bout a 99 gsr earlier today (rolling chasis) and i was wondering if a 94 gsr engine would drop right in and all electronics would match up. Has anyone done or helped do this swap before. Any help would be appreciated. tia
Old Feb 7, 2004 | 11:31 PM
hallsy's Avatar
Default Re: 94 gsr into 99 gsr? (hallsy)
can someone please help id like to order the engine in the next day or two.
Old Feb 7, 2004 | 11:36 PM
xteg95's Avatar
99 is obdII, 94 is obdI, engine will drop it inself cept the wiring harness is different.
Old Feb 8, 2004 | 12:13 AM
stevieteg's Avatar
Default Re: 94 gsr into 99 gsr? (xteg01)
it can be done. Just drop the motor in and use a jumper harness to an obd1 ecu. depending on where you live it might be illegal though.
Old Feb 8, 2004 | 04:26 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: 94 gsr into 99 gsr? (stevieteg)
Or you could use an OBD-2 engine harness, swap the injector plugs and distributor over from the 94, and then it will drop straight in.
biggrin5
Aug 16, 2008 07:07 PM
lilmike
May 15, 2006 08:03 PM
bboylito
Apr 5, 2005 11:49 AM
CountryStreetRacer
Oct 7, 2004 08:56 AM
FrankEXsteiN
Jun 28, 2002 10:52 AM
